Results 1 to 6 of 6
Thread: Harness wire?
    iceorphen
    Guest
    Harness wire?
    I've got a loose/frayed wire on my engine harness right at the front injectors. Any idea what this wire does, or is supposed to do.
    All 6 of my injectors are working fine.
    http://img15.imageshack.us/img15/8407/imag0120mu.jpg
    http://img34.imageshack.us/img34/2531/imag0121u.jpg
    http://img823.imageshack.us/img823/1117/imag0122rr.jpg
    http://img12.imageshack.us/img12/8035/imag0123zn.jpg
    thanks in advance
    Last edited by iceorphen; 03-09-2011 at 10:57 PM. Reason: pics showed up too small
    IIRC that is the rear o2 connector.
    iceorphen
    Guest
    I'm not throWing a cel, any ideas how to proceed? Do I need rear o2?
    Dubuque
    not to thread jack but yeh, do you need a rear o2? ive been curious about this cause the person that owned the car before me cut the wires from the rear o2 but im not throwing a cel though not sure why they would do such a thing but im planning on replacing it with a fresh new o2 sensor when it gets outta the shop. but i have been curious if you need one if i dont i guess ill save myself a 100 bucks
    "Where you come from is gone, where you thought you were going to never was there, and where you are is no good unless you can get away from it"
    wheatfield, IN
    is there a wideband in it's place? my PLX Wideband has a narrowband "out" option so I can run a wideband in the narrowband bung, and run a wire from the "brain box" to the ecu so it doesn't trip the CEL
    iceorphen
    Guest
    Well when i was under the car 2 weeks ago, i saw that my rear cats were gutted, I could see the o2 from below. Whether or not its wired is a different story.
