Results 1 to 2 of 2
Thread: oil cooler banjo fitting size?
    the BOSS of jellow supporter Feedback Score 0 a2j's Avatar
    May 2005
    Dairyland
    sold my oil cooler lines, now looking for banjo fittings. what is the size for those? and where can I get them? I know bolts are M16, and I have them. I just need those fittings.
    also, PM me if you have old/broken stock oil cooler lines that you wanna get rid of.
    Ft. Lauderdale, FL
    I would recommend using the stock lines for simplicity. If you cut off the stock lines, they have a barb fitting that you can put 3/8 hose on easily. You can also bend the metal parts into the required shape if you are careful. Of course, I also had a bunch of sets lying around. If you don't currently have them, you can use M16 x 1.5 to -8 AN adapters and AN hose. That will be more expensive, but it will look nicer.
  3. The Following User Says Thank You to RL7 For This Useful Post:
    a2j
