Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: PCV'less front valve cover....(pics)
    Pueblo, CO
    OKay, well I was putting a new pcv valve and the little notch broke off. Well, had a guy reweld some aluminum on and I put a hose barb on instead. I was going to tap into the old hole, but there is a small tube that if you drill into it it will break, plus I dont want shavings in the baffle. Well, this work out better than I hoped. You can see the difference in diameter from teh pcv and the fitting I put on. I use DR Krank vents so the PCV is pointless for me and very restrictive. What do you guys think?
    Mike
    Driving Vicki Crazy
    I use a threaded barbed nipple fitting that screws into the valve cover like a PCV and gives a barbed nipple to attach a hose to. You can get them from Mcmaster.
    -Chris
    Elko, Nevada, United States
    I need to do this and install my krank vents. Hopefully it will help my slight smoke on decel issue and not let stock pcv pressurize the heads anymore.
    Ft. Lauderdale, FL
    If you're pressurizing the heads, just put some open breathers on for a temporary (that may turn permanent) fix. The PCV valve is meant to be restrictive in high-vacuum situations to prevent too high a percentage of unmetered air from entering the system.
    Driving Vicki Crazy
    It also allows the valve stem seals to seal under vacuum. Otherwise they pass oil and you will see smoke out your exhaust.
    -Chris
    ^ I know somebody that happened to. He's Green, and you won't like him when he's angry
    Nobody likes me when I'm nice ether
    Alright so Sin, Ninja Performance, RL7, and green-lantern all have a breather or crank vents. How are all of you routing them? I've seen maybe 5 different routing setups on the board and a couple of partial pics in the past few days. What's working for everyone? Pics or diagrams would be a big help and explanation as to why people are routing differently.
    Last edited by J. Fast; 03-10-2011 at 11:46 PM. Reason: spelling and grammar like a 1st grader
    Well mine was all vented to atmosphere and of course it didn't push oil out of turbo seals anymore but soon after I started having VSS leak. Some have problems with this and some don't.
    Now I put the rest back to stock except for this. I installed krank vents so they would close under vac.
    So far it has seemed to work out well this way except I still get a little bit of smoke when I 1st fire it up at idle. I'm going to put another valve in between the rear head and the bubble and see if the extra vacuum helps seal the VSS. The valve will add some more resistance when venting the engine under boost but it should be OK.
    So that's going to be 3 vents total? As for now you reverted to running the stock PCV on the front passenger side, one crank vent on the front drivers side, one crank vent on the rear drivers side and what for the passenger side rear? What made you use a "T" from the front to rear on the drivers side instead of just adding a vent, was it still smoking or does it need to be that way to equalize the pressure in the heads because the block is split due to it being a "V"?
