The problem with switching pad materials is that the bedding process can cause uneven pad deposits when you switch. That's why you don't run track and street pads on the same rotors.
Interesting. I would figure the bedding process would wear off old pad material and some of the rotor. Do you know how the uneven depositing happens? Variations in the rotor surface?
Different pad compounds react differently. Most track pads are more abrasive which doesn't work too well with regular pad material.
