you need to run them in pairs. i would never run different offset wheels on the same axle. fwiw, i think rez and i were probably both referring to the FRONT perch. you can fit higher offsets in the rear, i believe. i would say your best bet is, if you have to use +50's, put a pair of them on the back and test-fit. if they don't fit past the strut, then you can always add a spacer. i would think that even if you DID need a spacer for the back, that 13mm would be sufficient--but don't hold me to that. the calculation i'm getting is that you'd end up with 14mm more inboard--without the spacer.
