What would a 18x9 +50 offset wheel look like? Would that stick out a lot?
my previous wheels i had 9" wide with 42mm offset with 255 tires all around. on the front it was like a mm or 2 from touching the strut tower on the inside. im sure +50 will touch tower. on the back there was plenty of space in the wheel well. front was flush, rear was sunk a few mm
you could use it but would have to use 235 tires, and clearance on the inside for the front would be extremely close.
1990 GTO - 12.50@115 15g's&supporting
Does a + 50 push the rim out or in? I thought it would push the rim out and stick out from the fenders.
I tried to read up on what offset meant but I'm more confused now than before.
Jojo's VR4 had a -9 offset in the back, with the extreme widebody look it was badass.
Originally Posted by Atrosity
That has what relevance to anything mentioned in this thread?
-Jason
Oh come on Jason, he used the word "offset" that counts for something doesn't it![]()
Would running a spacer to get close to stock cause any negative affects? Could I still take it to the track?
So you guys think a 18x9 +50 is possible? I'm desperately trying to find a Blitz Type 03 to replace the one that got hit a while back. I may have found a couple. These rims are ultra rare and I only have 3...
