Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: 3KVT 1993 VR4 Dyno Pulls, GZP 16T's
    I'm Kind Of A Big Deal
    So, we've had a long run here with Marc, but we're finally dialing it all in now.
    We did a few pulls on Saturday night for him with his new GZP 16T turbos, but could not get past 12psi without breaking up. So, we are upgrading his ignition system, and will be re-dyno'ing it again later this week... hopefully to put down some nasty numbers!!!
    Stock engine, FMIC kit, borla exhaust, stock MAS, with an emanage blue, 560cc injectors, etc. @12psi we made 322AWHP.
    Enjoy
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
  2. The Following User Says Thank You to Emilie@GZP For This Useful Post:
  3. #2
    Christmas tree style FTW!!!
    1993 3000GT VR-4
    MHI 16-T's and supporting mods.
  4. The Following User Says Thank You to 3KVT For This Useful Post:
  5. #3
    August 2010
    Chicago
    hot looking VR-4..
  6. The Following User Says Thank You to NOMIEZVR4 For This Useful Post:
  7. #4
    vancouver bc
    im liking the torque curve.
    subscribing to see end result
    1990 GTO - 12.50@115 15g's&supporting
  8. #5
    You shouldn't need to upgrade anything in the ignition system to run 12+ psi. We're talking about 322 AWHP with a mid-grade TD04 ceiling. What on earth are you ugprading?
    I have a stock ignition system other than MSD wires (which aren't necessary) and copper plugs @ .020-.022" and I've run up to nearly 33 psi cleanly. Trevor had a completely stock ignition (with regapped iridium plugs) system at basically the same levels.
    Tighten the plug gap. If that doesn't work, replace the coil pack with new (or newer) OEM. If that doesn't work, suspect the PTU. Anything more is a waste of money.
  9. The Following User Says Thank You to AdamVR4 For This Useful Post:
  10. #6
    I believe Hans found that one of the coils was bad/not great.
  11. #7
    No surprise there. These cars are old. The ignition was one of the very few over designed systems on the car, haha... And unfortunately, people tend to upgrade it when they don't have to and often create more problems than they solve.
  12. #8
    We had discussed with Marc possibly upgrading to the HKS DLI, but we all agreed we'd try swapping in a good stock one first to see if that solves the problem. He's been having this issue for quite a while now, so, the frustration with it was enough to want to replace everything and be done with it
  13. #9
    haha, yeah, since fuckin '03 it's been doin this shit, and I never thought to check the coils. The new plugs and wires last spring helped out tremendously, but the coils are still factory and Hans said one of them had way higher resistance than a new factory set. Can't believe I never checked em before, but I'm still learning about these cars.
    and the frustration did make me just want to say fuck it and get a whole new system, lol. Hopefully a new set of coils will clear her up and let her scream out 400awhp like she's supposed to.
  14. #10
    Rancho Cucamonga, CA
    Were you ever able to get some new coils in there? How many miles are on the current ignition setup?
