Was looking around on eBay and found this. OBD1 to OBD2 Mitsubishi 12 pin Connector adaptor cable - eBay (item 130492994900 end time Apr-01-11 0720 PDT). Will this work on a 1g 3/s. I plan on getting a Bluetooth adapter and using my phone.
I don't think it will work because the bluetooth adapter will be trying to communicate at 10400 baud, that's incompatible with 1953 baud of OBD1.
I have used a Snap-On Modus with the HYUN-2 adapter [basically just an OBD1 plug] and it communicated fine. I didn't think to check things like knock etc but I could see injector duty cycles, engine revs etc and do a system check and shut down injectors one by one etc.
Waiting install
Build Thread
Is there anyway to log without have to buy a bunch of stuff.
If you have a laptop with a serial port [or a USB to serial adapter] then you can download the programs and make a logging cable. The parts will cost all of $20.00
I tried but the wire didn't work. Can you take a look at my wire and are what I did wrong. http://www.3sgto.org/f2/my-data-logg...rect-3989.html
