Results 1 to 10 of 28
Thread: Full throttle "hesitation"
    Forum User Feedback Score 0 1993RT/TT's Avatar
    Lincoln
    I own a 93 R/T Turbo that will not rev past 4000rpm at full throttle. When driving it nicely it can rev all the way to redline but after going about 2/3 throttle is sputters and actually slows down. Logging the car shows no knock and I did notice the injector duty cylce actually went from high 60% down to 40%. It also makes a very loud popping sound that sounds like its coming from way over on the passenger side. Any help or ideas would be appreciated. I should also mention that the ECU is freshly rebuilt and switching ECUs makes no change. Thanks
    Jake
    Fowlerville, MI
    Change your spark plugs/wires recently?
    Stress free wheel gap. Not Verified Feedback Score 0 YoshiBishi's Avatar
    Jan 2011
    Morrisville, NC
    You might want to check the gap of your plugs. Try something around .030 or .028.
    Member Not Verified Feedback Score 2 (100%) DK77's Avatar
    Feb 2011
    Scottsbluff, NE
    Could be a boost leak
    Jan 2011
    I just sorted out a similar problem, i chased it down and found it to be a pretty bad vac leak causing me to lose ~6hg of vac.
    Lincoln
    I did change the plugs recently but not the wires. What is a good way to check for a boost leak?
    Member Not Verified Feedback Score 4 (100%) dpartinvr4's Avatar
    wheatfield, IN
    those IDC's, if they are "true IDC's" are way to low. your ECU must to be advancing the hell out of your timing. what timing does your log show?.........is your FPR broke? or do you have bigger injectors in without a piggyback system to adjust afr?
    Forum User verified Feedback Score 3 (100%) 3000GTCSULB's Avatar
    Spark plug wires. I had the same problem.
    Forum User Feedback Score 1 (100%) 3KVT's Avatar
    I'm dealing with the same issue pretty much and Hans thinks its spark blow-out. So I'd check plugs, wires, and coils too (one of mine has way more resistance than the others do, which could be causing the blow-out). Here's a good write-up on homemade pressure testers if you're mechanically inclined. courtesy of stealth316.com
    Stealth 316 - Intake pressure tester
    1993 3000GT VR-4
    MHI 16-T's and supporting mods.
    Lincoln
    Quote Originally Posted by dpartinvr4 View Post
    I'll hook the logger up again tomorrow and see what it says for sure on the timing and IDC
