I did not use the Supra. My Supra failed after almost a decade, and I bought the Kyosan as a replacement but also ordered a new tank assembly from Mitsu because my old one looks crappy, and the wiring looked weak. I got the assembly before the pump and had issues with the car idling and at WOT so instead of introducing new issues my replacing the stock pump with the Kyosan, I just put the assembly in with the OEM pump. However, now that I know the issues are somewhere else, I am planning on putting the Kyosan in. I also put the stock pump relay back in the socket. The socket used to get really hot with a jumper and I kept blowing relays on my re-wire, so I put it back to stock. I think the old Supra Denso was drawing too much current because it was stalling and it eventually just failed. The stocker doesn't seem to make the relay socket hot and since it works well at staged voltage, its also not re-wired.
Sam
