Results 31 to 40 of 59
Thread: MSD DIS-4 install help.
  1. #31
    I AM IMPORT POWER
    Driving Vicki Crazy
    Yep, you are missing the wire harness for the MSD DIS. And the Bypass jumper plug for the DIS as well.
    -Chris
  2. #32
    wheatfield, IN
    the wiring harness came, i'ts got two bundles comming off of the plug, idk what the bypass jumper plug is. and where do I put the DIA things.
  3. #33
  4. The Following User Says Thank You to cjbyron For This Useful Post:
  5. #34
    wheatfield, IN
    what do you guys hook your "Two-Step" switch up to?
  6. #35
    I AM IMPORT POWER
    Driving Vicki Crazy
    Quote Originally Posted by dpartinvr4 View Post
    Clutch Switch.
    -Chris
  7. #36
    wheatfield, IN
    Clutch Switch.
    -Chris
    isn't that a "ground" switch though, this needs a 12v switch?
  8. #37
    I AM IMPORT POWER
    Driving Vicki Crazy
    Relay.
    30 to Positive 12V
    86 to Positive 12V
    85 to clutch switch ground output
    87 will switch to Positive 12V out for MSD when the clutch switch is triggered and putting out ground
    -Chris
  9. #38
    wheatfield, IN
    Ok, now for the coils, this is what DuTTch sent me, I'm assuming the right side of the coils are the negative, and the left is the trigger, but he didn't connect the middle coil to the "what I'm assuming is the ground" that connects the outside coils.
  10. #39
    Seattle, WA
    Go to MSD website, select product - coils, select the coils, click instructions.
    http://www.msdignition.com/uploadedF...structions.pdf
  11. #40
    wheatfield, IN
    i did, dutch hotwired these, and theres only two wires whereas the MSD sites instructions show 4 wires, two triggers and two +or- wires, IDK how you could use either but it shows it that way.
