Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Help Identifying Turbo
    After getting 101% IDC's at 13psi the other day I started getting suspicious about the mods. Going to check the fuel pump & injectors next weekend. The car supposidly has 550's but after logging those IDC's I'm not so sure. It was one of those things I didn't think I would have to check, considering the custom ss dual feed fuel setup.
    San Francisco
    Oh, yeah that's not right for 550s. I was right around that IDC with stock injectors on the 13Ts at the same boost. If you were told it had 550s on it, that's too bad. Is it tuned for 550s? If you go into your SAFC or whatever piggyback and check its tune, that'll tell you in a hurry.
    Feb 2011
    Scottsbluff, NE
    Don't the loggers usually show higher IDC's than what is actual?
    Using an arc2-gp with 87mm MAS and my tune is consistant with stock injectors. Kind of hoping my fuel filter is clogged up, somehow causing all of this. Wishful thinking.
    Just checked the injectors, they are Denso 550's. Wasn't expecting that.
    San Francisco
    That is the strangest thing. ???
    Support NG!
    After I get my ECU fixed I'm going to check my fuel pressure, my guess is the afpr was set too low.
  8. #18
    Just a little more info for anyone interested, fuel pump was a Denso Cosmo 20B. Relay was bypassed w/ stock wiring.
  9. #19
    Fuel pressure was properly adjusted, the fuel pump was slowly dying. Explains why I was able to pull 18 psi to redline a few weeks prior to the start of all this.
