Results 1 to 7 of 7
Thread: LOUD pop when reved
    Jan 2011
    LOUD pop when reved
    I have a louuuuuud popping sound when I hit the throttle, sounds like its coming from front turbo or intake pipe.
    When I unhook the MAF, the popping goes away entirely. Idle seems better also but it could just be me...
    Hook MAF back up, pop sound returns.
    Is the MAF shot?
    Cazenovia, NY
    Sounds like you're running lean and backfiring. Once you disconnect the MAF, the car goes into limp mode and the ECU determines the AF ratio and makes the car run pig rich, hence the reason your backfiring disappears.
    Forum User Feedback Score 0 SuperFast3000GT's Avatar
    Nashville, TN
    Quote Originally Posted by x2xtreme360 View Post
    What's that mean for him? Probably has a boost/vacuum leak?
    Cazenovia, NY
    I would start there for sure. Probably a vacuum leak.
    Jan 2011
    Ill check it out all my connections during fmic install.
    Is vac leak test similar/same as boost leak?
    thank you
    Vac leak testing would be covered under boost leak testing, yes. That's definitely something to check for. I HATE debugging these car runs worse with MAF plugged in situations...
    Jan 2011
    I've had intermittent hesitation problems since I've owned it, the other day it was stuttering BAD, almost no power on accel until I hit around 3000. Really wanna get this sorted out once and for all
