I have a greddy v2 eletronic boost guage that is powered by a 3 bar sensor. It reads from -30 in/Hg to 30 PSI.
I've been told that you can't share the map signal between the gauge and the emanage ultimate.
So, I had an ebay MAP sensor (from Xaviar) and harness for the emanage, but after using it for a while I was really skeptical of its accuracy, especially since I plan on going to a map based tune and my engine depends on this sensor to be right.
Rather than spend $135 on a greddy sensor and harness, I decided to try to share the signal from my greddy gauge. I hacked off the sensor off the aftermarket ebay map harness and soldered it into the Greddy gauge's harness.
I only spliced the ground and signal (white) and left the red source from the emanage unhooked, because I had concerns that 2 power feeds may corrupt the signal.
I am very pleased to say it works perfectly. The gauge and emanage are DEAD on.
I hope this saves someone else some money. You can get the v2 boost gauge for $80 on ebay right now.
