Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: car breaks up around 6k rpm
    Midland,MI
    Just put 19t's on my stealth. Now it breaks up real bad at around 6k rpm, I replaced the plugs and checked for vac leaks and cant find any. Could it be the car is needing a tune because of the new 19t's, went from 13g's, so there is a lot more air going through. What else could it be?
    wheatfield, IN
    New plugs...it's spark blow out man...what did you gap too?
    SoSoCal verified
    what kind of ignition system do you have?
    Midland,MI
    .032 brand new ngk iridiums, msd wires. It did the same thing with my ngk coppers gapped to .032. That's why I changed the plugs out.
    Midland,MI
    Should I get blowout at 16.5 psi?
    wheatfield, IN
    try .028 and see if that helps...it's free so it's a good place to start.
    Might want to get a HKS DLI.
    Stress free wheel gap. Not Verified
    Jan 2011
    Morrisville, NC
    Do you have one? If so, did it help with spark blowout at high load?
    Midland,MI
    I cant afford to get one of those. why would it do it with the 19t's and not the 13g's?
    Quote Originally Posted by YoshiBishi View Post
    Going to have to get back to you the next time I change the plugs. I really want to do some testing with it to see how much it works at different plug gaps.
