That's the only banjo bolt that'll ever be used in my car (sans Earl's fittings on -AN lines). I've tried non-OEM bolts and have found either their openings to be insufficient, or their seals to be... less than ideal. Wise man once said that if you want a fast car, there's two ways to do it. 1) Use the right combination of parts and the right driving, or 2) Throw so much money at the car that it has no choice to be fast.
Get the damn OEM bolt.
The other one is
1. Fast
2. Cheap
3. Reliable
You can only have 2 of the 3.
Potato..
1991 Stealth RT/TT
Ok I guess I can feel pretty good and pretty bad.
The good news: My 13T's and seat of the pants no log tuning matched Rays DR650's, wooo hoo.
The bad news: I'm still trying to get into the 11's.
What the op fails to understand is Ray and Matt have a ton of experience driving in I don't care if I break it (and often breaking it) capacity. According to Rays' math my car after my next tune would run 10's. (pretty sure upping the fuel pressure so I don't run out will get me 500hp) The car weighs 3700 so a little less than stock. But if ever get 11.5 and get kicked off the track my life is complete.
The other thing Ray and Matt have to their advantage is knowledge. Here's some things that stuck out at me as a no way.
Stage 2 clutch - That tells me you've never felt over 350hp cause that clutch will be worthless too you.
Make my TC bracket - don't even know where to start on that one.
Glass roof - big strike against you in weight reduction.
Don't get me wrong, go for it with all you got. It will give you the chance to learn a lot. It's really not about being super human but simple physics learn them.
Although I don't want to encourage you too much. After all I'm 1 hp off the the 13T record and plan on owning it with a good gap pretty soon. Don't want you raising the bar too high.![]()
Most powerful 13T car in the world @501awhp, PTE 780CC injectors, AFPR, E85, Greddy Profec B, 3.5" Granatelli MAF, MAFT, SS Headers and O2 housings front, 3SX downpipe, CRX racing FMIC, Dejon intake pipes, Ground Controls, Maximal adjustable rear control arms, Maximal TC Brace, Poly front and rear mounts, Vacuum Reduction, EGR block off plate, Hot Wired Walbro 255 and inline Walbro 255, Southbend stage 3 clutch, Slotted and vented rotors, SAFCII, Turbo XS BOV, 3SX FP hotwire, Seatle Short Shifter, Jackhammer timing gears: Best 1/4 mile 12.33 at 114.9 mph 1.79 60ft.
Just here to harass dpartinvr4 some more. How's that 10-second car coming along?
