Hello,
I´m from germany and I have bought two used heads with these camshafts
They have a slightly highter lift that the stock (about 1-2millimeters).
The owner told my they would be hardweld N/A Profile cams.
Can somebody tell which cams I have?
Unfortunatly one exhaustcam got damaged
Is it possible to combine the two hardweld intake camshafts with the stock exhaustcamshafts? Is there enough space (the valves a 1millimeter oversize) so that the pistons does not hit the valves because of the highter lift?
Thanks for you help!
