Results 1 to 10 of 18
Thread: should any of my safc setting be in the positive?
    Forum User Not Verified Feedback Score 1 (100%) Kilo_SME's Avatar
    Stock tt injectors and NA ecu. Is that running running to rich? I don't have a wideband and the logger I have is useless. Any help would be great thanks.
    Member Not Verified Feedback Score 4 (100%) dpartinvr4's Avatar
    wheatfield, IN
    how much boost are you running?
    Wastegate boost.(7psi) and its a atx
    wheatfield, IN
    then you don't really need an safc....but no, everything should be set at zero.
    Are you sure? With a NA ecu?
    Administrator Feedback Score 3 (100%) Alan92RTTT's Avatar
    Madison Heights, Mi
    Yes, you need the afc with the NA ecu.
    What fuel pump?
    I think they should all be negative but wait till someone with more experience posts to be sure.
    wheatfield, IN
    Quote Originally Posted by Kilo_SME View Post
    My bad, I didnt realize you have an na ecu....in the positive might be ok then, it depends on some other things..i.e. Fuel pump, injectors, and.a dataloger would really help....do you know if the na and tt engines fpr's are set to the same pressure? And wich do you have?
    I lack color... verified
    Feedback Score 1 (100%) Greg E's Avatar
    Aug 1998
    Not sure how you're going to tune your car without knowing what the narrowbands are communicating with the ECU but it's not uncommon to richen up the lower rpm values then gradually lean them out.
    you need a wideband and a logger, bare minimum.
    I have a logger but it doesn't show any knock sensor, and I think the a/f is in volts or something. The car ran pretty good with the the high settings in the positive. I rather run too rich then too lean, but the way gas is going up I can't afford that.lol. Also im still on the NA fuel pump and fpr.
