Page 885 of 892 FirstFirst ... 385785835875883884885886887 ... LastLast
Results 8,841 to 8,850 of 8916
  1. #8841
    Yes
    Sent from my SM-G900V using Tapatalk
    I used this when I rejoined mine:
    Walker 35959 Hardware Sealing Compound
    I bent my clamp back and smothered this stuff on real heavy, clamped it back down and wiped the excess into the outer seals. I also cut off a little rise up on the clamp to get a tighter squeeze on the slip joint beforehand.
    Dremal with a cutting wheel made quick work of it:
    Have any other questions, let me know
  2. The Following User Says Thank You to 2fnloud For This Useful Post:
  3. #8842
    Man vs 3/S verified
    Kingston, WA
    Hmm maybe i just need to tighten it more. I wrapped the front section with fiberglass tape a few times, maybe it needs some more layers of tape to seal up on the rear section sliding over it.
    Whatever that factory fiber/material is on the inside of the rear section is crooked and overall in bad shape. I added an inch to the rear section hoping it would slide on farther and seal up. I will probably loosen it and see if i can slide it a little farther back but the tips are in the perfect position right now, i dont want them sucked under the rear bumper.
    Anyways, it wont be a thing of/when i do my side exit i have dreamed about for awhile.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  4. #8843
    Mad JDM Tite
    STL
    Where on the side would it be exiting?
  5. #8844
    May 2012
    Houston, TX
    Just a bath and some driving this weekend.
    Good to see you posting James. Seeing your post reminds me I need to find my bracket that bolts to the firewall that the fuel filter bracket bolts to. I've somehow misplaced it from both cars.
    Hey Brian! I was just catching up on your new build thread. Looks like it's coming along!
    '91 3000GT VR-4 Silly car, get down from there. You're not a plane. You don't even have wings.
    '03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
  6. #8845
    I was going to send a picture of this to Nate tonight, I have the same goop. Works great.
    Man vs 3/S verified
    Kingston, WA
    Quote Originally Posted by 95gto View Post
    Driver side, the rearward most section of the rocker panel. Oval tubing, at least when we 90 degree it towards the rocker. Maybe 2 inline magnaflow 3"i.d/4"o.d mufflers or some vibrant race mufflers. Dad is a welder and can do whatever. I was worried that the rear bumper would look funny with no tips in the exhaust area but it looks normal, actually.
  8. The Following User Says Thank You to R/T93 For This Useful Post:
  9. #8847
    What sort of weight savings, Nathan?
  10. #8848
    Mad JDM Tite
    STL
    So is the plan to bring it out below the side skirt or through the side skirt?
  11. #8849
    Needs shielded either way, eh?
  12. #8850
    Mad JDM Tite
    STL
    If I'm picturing it correctly I think it will.
