look into the Molshine Heat-Shrink Tubes media cartridges, cheaper and have great ratings on Amazon like 8.00 per in all three sizes
https://www.amazon.com/s/ref=nb_sb_n...t-Shrink+Tubes
Making a Y-Pipe:
Need to order one more T-bolt clamp, cut the 3" tube to size, bread the ends. I also need a BOV, I want nice, I want loud, hate all you want, I want that Fast and Furious blow off valve sound.
Looks good, Steve. Though it might be a hair long ;-)
I borrowed a bead roller from a co-worker that works great. Didn't know how expensive it was until I just looked it up.
https://www.amazon.com/Vibrant-Perfo.../dp/B00LF4T82Q
Alternatively, I have also made a bead roller/crimper out of some channel lock pliers, exhaust clamp, and crankshaft woodruff key. It worked well too, just not as pretty and a lot more work. Also, mine only works on 2" pipe. Although I'm sure you could cut the sides of the exhaust clamp to accommodate different pipe sizes.
https://www.google.com/url?sa=i&rct=...05513375767560
As far as BOV, I couldn't agree with you more, louder is better. I run the Turbo XS RFL. You can get practically identical knockoffs on ebay for a fraction of the cost. We just picked up a nice blue one for Char's Vr4.
I also saw this video too:
That's how I have mine set up, works awesome, I just wish I had done it sooner. Hard to find the reducer coupler that size though (3.5 to 2.75). From what I remember, it's best to have the longest possible straight section of pipe in front of the maf. I even relocated the BOV to the wheel well so it doesn't cause turbulence. Probably not necessary, but I like having it out of the engine bay. Sounds even louder now lol. Would be sweet to run two of them with a dual core setup.
For that reason I'm more than happy just to borrow it.
Please show some pictures of your MAF placement, and how you got the BOV to the wheel well.
Received my 94 to 98-99 ECU harness back from Antero. It needed the pin conversions for the active exhaust, and while he had it I had him add the extra pin outs on the 98-99 side of the harness for the W/B 02, MAP, and the optional 12V triggers.
I also took the time to label the pins that are used for NLTS, 12V trigger, MAP sensor input, W/B O2 input.
I also labeled pin 58 on the 94 side (pin 45 on the 98-99 side) as the tachometer, remote starts need the tacho signal to know that the car is running. I have mine installed but that wire on the remote start system is running up behind the dash and to the gauge cluster. At some point I will be pulling my dash to replace the vents and this wire run this way will prevent the dash from being free to be removed. IF I tap this wire at the ECU, I will not have this problem. BUT I do no know for certain that the wire I labeled for the tachometer is correct, does anyone know?
Antero FTMFW.![]()
Made a Y=Pipe:
