Page 882 of 892 FirstFirst ... 382782832872880881882883884 ... LastLast
Results 8,811 to 8,820 of 8916
  1. #8811
    Canaan NH
    Probably not the problem, but it looks like the rear main seal is leaking.
  2. #8812
    Oct 2015
    Well it turned out to be the vcu. Had the trans rebuilt, ended up needing a new second gear. 1-2 synchros. I ended up using parts off another trans and on the first drive everything was smooth. On the second drive the 2nd gear grind came back. I'm super annoyed with the car. The builder inspected the replacement parts which seemed to be in pretty good shape. I'm stumped. Any ideas? I've adjusted the clutch pedal and nothing changes
  3. #8813
    Taichung, Taiwan
    I busted my knuckles and sliced my fingers repeatedly. One end link installed, one cross member dropped. I didn't realize I would have to drop the whole bottom to do stupid LCA's. Many many more things to go.
    1995 3000GT VR-4 Black
    K&N Air Filter / Topline Engineering Ground Kit / Precat Eliminators / Walbro 255 / DNP Downpipe / 3SX Fuel loop / JDM EVO MR BOV / Hallman Pro RX / 3SX Single Pass Radiator / Tein S-techs / 3SX Rear Control Arms / 3SX Custom Poly Motor Mounts /
    306.5hpawhp 320.5awtq @14psi
    Sold - 1994 Mitsubishi 3000GT Pearl White Base
  4. #8814
    Working on making my gauges in the A-pillar more OEM with connections at the gauge in the pod, not just at the base of the A-Pillar.
    This started from needing to pull the gauges out to have the needles changed from white at day to red at day.
  5. #8815
    Jun 2011
    Sweden, Gothenburg
    Evo X test fitment. Got these Wheels a while ago was planning to run them this summer but car didnt pass inspection.
    Anyways fits pretty well just as is. Ideally I will want a 10mm spacer on the rears. And i need a couple degrees camber on all corners.
    When/if I do the fender flares I would need massive spacers for these but probably just sell them by then
  6. The Following User Says Thank You to Ange For This Useful Post:
  7. #8816
    Perfecting my harness making skills:
  8. #8817
    Looks like your mouse is contemplating a meal, Steve...
  9. The Following User Says Thank You to j2k4 For This Useful Post:
  10. #8818
    Oct 2011
    Sundsvall, Sweden
    Nice label on the cable. How did you make it?
  11. #8819
    Quote Originally Posted by Unlogic View Post
    Label maker that can print on heat shrink tubing:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  12. #8820
    Oct 2011
    Sundsvall, Sweden
    Thanks!
    I had no idea that Dymo had heat-shrink tubing in their product range.
