Page 870 of 892 FirstFirst ... 370770820860868869870871872880 ... LastLast
Results 8,691 to 8,700 of 8916
  1. #8691
    Quote Originally Posted by DK77 View Post
    Waiting for some boxes with stuffs in them to show up
    round shiny things?
    Never finishes any verified
    Wake Forest, NC
    Cleaning up the garage and packing away as much as I can. Trying to get every single thing out of the shop that I can. Then pulling in the stealth to strip it all down bare. I have 5 weeks off in Dec so planning to paint the car during that time. So lots to do in the next 2 months! Was actually thinking about setting up cameras in the shop to record it all....
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #8693
    Rochester Hills, Mi
    I couldn't do the camera thing. It just wouldn't work with my ADHD.
    95 Base 3k: 6G74/TT/AWD conversion
  4. #8694
    Rochester Hills, Mi
    Bought a minty fresh one owner, 21k mile, fiji blue vr4.
    It does have a bit of wheel gap up front, but that will be taken car of once I put the engine back in.
    It has one scratch on the rear quarter panel. It will be taken care of.
  5. The Following User Says Thank You to Uniuno For This Useful Post:
  6. #8695
    Damn you! I bid $5100 on that, and tried to bid more with 3 seconds left but it didn't go through.
    Quote Originally Posted by Uniuno View Post
    Built motor, DR750s, AEM and Meth
    http://www.802projects.com
  7. The Following User Says Thank You to fastfalcon94 For This Useful Post:
  8. #8696
    Wake Forest, NC
    Sounds like you got outbid...LOL
  9. #8697
    Yeah, stupid "confirm" screen messed with me. Would have been better if I wasn't on my phone with crappy service in my friends pit crew for a demolition derby. I bid 5500 with 3 seconds left, then some stupid confirm button popped up at the bottom of the screen. I clicked it but I guess it wasn't fast enough. Curious what your "max" bid was. I have a 6 speed setup and 4 bolt motor I was going to put in it to resell. The seller said he'd take $700 off my bid too if I didn't want the stealth. At least I scored a pretty sweet targa vr4 this week.
  10. #8698
    Feb 2011
    Scottsbluff, NE
    round shiny things?
    I think they're matte silver.
    1995 Dodge Stealth R/T Turbo
  11. The Following User Says Thank You to DK77 For This Useful Post:
  12. #8699
    I had intentions on working on the Stealth this weekend but I ended up not being home all weekend.
    I did help my cousin yank the engine out of a project Talon his girlfriend bought. We bolted it to the stand, flipped it over, yanked the pan and as soon as I grabbed #4 rod I knew I had found the problem.
    Pulled the cap and found this
  13. The Following 2 Users Say Thank You to stealthee For This Useful Post:
  14. #8700
    Rochester Hills, Mi
    Quote Originally Posted by fastfalcon94 View Post
    I was actually at the guy's place in the middle of BFE looking at the cars with about 20 minutes left on the auction. I only had one bar of service to work with so I had to make it count. I put in a max of 6k, so I'm glad your last bid didn't go through, would have cost me even more! lol.
    That is a sweet targa, looks like it was done well too.
    I got the stealth home over the weekend and started pulling it apart. I got it running, but it was leaking fuel out of the return line at the tank so I couldn't leave it running for long. Didn't sound like valves (as the ad stated) but I checked them out anyway. The heads looked fresh and have '99 lifters in them. Pulled a lifter out and there was a decent amount of trash in the bottom. Compression test was 150psi across the board. The oil pan was dented and leaking so I pulled it. Lots of glitter in the bottom of the pan. Did the wiggle test on the rod caps and found a loose one. "6 rod bearing halves decided to get kinky and hopped on top of each other.
    So that engine is toast.
    Not that I would swap a 141k engine into a 21k mile car, but it would have been nice to use as a core for rebuild. I might end up using the 2 bolt that I have in my white car. Just need to have the 3.5 rebuilt first.
