Originally Posted by
Uniuno
They are Kinugawa's with the anti-surge housings. I'm looking forward to actually getting some good numbers from them, since it seems nobody else has.
Been working through some other issues in prep for BRG.
I took the 20s off and put the 18s back on. The 20s rub and are stupid heavy, but they look good!
Changed the rear O2 sensor, it was getting lazy. Seems to be better now.
I've been trying to get the coolant temps down, but nothing seems to help. I know I need to add some ducting for the radiator. As a temporary attempt, I removed the thermostat. That did exactly nothing. Still running 220. I'm running Spal slim fans, going to try swapping in at least a stock fan or two tonight. The big fan doesn't fit with the front turbo wastegate solenoid where it is. If I can do two stock AC fans I bet it will cool better than the slim fans. It stays hot on the highway so that tells me I need ducting, I'll have to do that after BRG.
The AC hasn't worked for years since I took it apart. I put a new dryer in it and vac'd it down and added a couple cans. Had to do some Idle adjustments with Chrome, but it works now. Too bad I can't use it until I get the temps down.
