Page 863 of 892 FirstFirst ... 363763813853861862863864865873 ... LastLast
Results 8,621 to 8,630 of 8916
  1. #8621
    Key Largo, FL
    Quote Originally Posted by Uniuno View Post
    We went the whole NG without dropping a trans, you should have said you needed the clutch done!
    I still remember the 3SX crew swapping the clutch in Eric's car in about 30 min. during the Memphis drags. That's why we need those guys to attend again.
    2013 NG: 1st place, FWD Drags
  2. #8622
    I could imagine a crew of people who work on 3s's a lot doing a clutch swap in 30 minutes. Hell one time I dropped the trans out of my car laying on my back in the driveway in about 40 minutes by myself with having to run into the garage for tools as I needed them. Had I had 2 more people with the experience of removing transmissions that I have it probably could have been done in that time period.
    Then again, I don't know many people who have removed a 3s trans as much as I have.
  3. #8623
    NA transmissions are super easy. After a few times its not even a big deal.
  4. #8624
    Sep 2012
    Decatur, TN
    Well, most of what I've done is work on piecing together a stroker motor for the car, but no details to release about that yet. And picked up a set of 68HTAs to go with it for now, although arm0red1 is going to work on something custom for me as well.
    And...I went and bought another motorcycle Because having 2 in the garage that I'm never home to ride isn't enough.
  5. The Following 2 Users Say Thank You to sergechronos For This Useful Post:
  6. #8625
    VERY nice The best looking Daytona color scheme, by far.
    Sep 2012
    Decatur, TN
    Much obliged. It's a very nice one, probably my #2, favorite would probably be the Caspian Blue with gold accents that they also had for a year or two. The phantom black is nice though, and the gold accent is a beautiful touch. If I end up doing a black VR4, I'll probably end up with golden accents similar in tone to this.
    Already on the list is a better exhaust (current Two Brothers is pretty loud and rough) that has ceramic coating to reduce heat and improve VE, deleting the EXUP and rerouting the secondary air set up before getting it dyno tuned. Have a set of Helibars on the way to improve the location of the grips and improve comfort, little longer as well so better leverage when I want to get aggressive with it. Watsen flush mounts that are already color matched to the body (ended up being rather expensive, but best flush mounts you can get IMO.) Set of tank grips are on the way, as well as a complete HID projector retrofit for better night time visibility.
    Eventually will be getting new levers and a new wind screen, but probably going to wait till this winter to do it. Also going to go ahead and check valve clearances before long and do a complete brake job, regrease wheel bearings, etc. etc. Lots of little (but expensive) maintenance to be done over the winter.
  8. The Following User Says Thank You to sergechronos For This Useful Post:
  9. #8627
    Aug 2015
    north carolina
    i put a new brake light in the 3000gt. yup thats it lol
  10. #8628
    Replaced the peeling, old window tint on the driver and passenger side doors of my Black 97 VR4. Can't believe I waited this long.
  11. #8629
    Quote Originally Posted by 93STLTH View Post
    Gave the Stealth a good bath after the drive home from the NG. I got rained on in Kentucky, Tenn, and Florida. I started to assess the list of things the car needs done in my mind, it's quite a bit. The clutch needs replacing and so does the timing belt and water pump. My exhaust needs to be adjusted, my muffler got hooked coming off of Marks trailer after the ECG and now it's hitting something under the car. A rock hit one of my fog lights, breaking the lens. I've been thinking about swapping the HID's for LED's, so I guess now is the time. I also busted my front lip on a curb in Indy, so I guess that means a new RetroSpec carbon fiber lip to replace that. Already ordered a new MAF, the one in the car is original. Although it still works, it's noisy as hell when I accelerate. Radiator needs replacing, it's probably more than 15 years old. Oh, and I still haven't figured out what wrong with my cruise control. These 1200 mile drives are tough enough, not having cruise control makes it even worse.
    How the hell are you Tom. I still talk to Tony and Dale some. What happened to Frank? Put my 97 VR-4 on the road in 2013. The 92 is on Jack stands in the back yard. Have a nice 4th. Dave.
  12. #8630
    Rochester Hills, Mi
    GF bought a 91 SL that had some issues, I found even more wrong with it once I started digging into it. Whoever worked on this car before needs to put the wrenches down and pony up for a real mechanic to do the work. Some of it was very dangerous.
    What I've found and corrected so far:
    DS tie rod end nut was finger tight.
    PS tie rod end nut had two washers under it, only leaving a few threads holding on.
    Passenger side brake caliper was reinstalled with a twist in the brake line.
    Intermediate axle shaft was only held to the block with one bolt, finger tight. The other bolt was the wrong thread pitch and only put in a couple threads. I was able to find the correct bolt and repair the threads.
    Still need to do:
    PO replaced the radiator, left out the AC fan, didn't transfer over the sensors to turn on the main cooling fan. Also for some reason removed the resistor to control the low speed.
    I already replaced the whole power steering rack because it was all kinds of blown out. 2nd gear has a good grind so I'll be swapping in a new trans at some point. Other than that it's mostly cosmetic stuff.
    95 Base 3k: 6G74/TT/AWD conversion
  13. The Following User Says Thank You to Uniuno For This Useful Post:
