Page 858 of 892 FirstFirst ... 358758808848856857858859860868 ... LastLast
Results 8,571 to 8,580 of 8916
  1. #8571
    Member
    Arvada, CO
    Yesterday I replaced the spark plugs as I was getting a little bit of a misfire when it was cold and the old plugs looked a bit fouled, also replaced a vacuum cap that was badly cracked and leaking so hopefully between the two the cold miss is gone. Also, I had previously bought the solid shifter bushings but the for/aft movement seemed to bind a bit so I had put the old bushing back in for the mean time and figured out what size spherical bearing to order. Finally got around to pressing the spherical bearing in yesterday. Now if only I could get rid of the last left/right slop when its in gear but that is coming from the shift tower on the trans itself so not sure what to do with that yet.
  2. #8572
    Aug 2015
    north carolina
    still daily driving the 3000gt. waiting for my GTO rear garnish to get here! kinda thinking i should do a front end rebuild with ball joints, bushings, etc since i am, getting alot of shake at 75mph and upward. the wheels are tight but i think that since everything on it is stock (57000 miles as well) its not so much mileage but the age getting to it now.
  3. #8573
    Sep 2012
    Decatur, TN
    Well, been on the road a lot for work so my progress for anything has been limited. Swapped the MBQuart components in my BMW back out, didn't like the results. Went to Bavsound for a plug and play upgrade. Little quieter than the OE speakers were, but the sound quality is a bit better and more balanced.
    Other than that, picked up a 6G74 long block that I'll be selling parts off of while working towards building a 3.7L with MIVEC heads (assuming it all comes together like I'd hope.) Also picking up yet another bigger set of TD05 turbos and a 2G shell (that's green )
    Going to look into having the engine bay cleaned up and shaved a bit, and having it professionally repainted. May still do it myself, but..mehhh. That'd be a multiweekend project.
  4. #8574
    Finally swapped out the horrid front leather seats with a clean set of stock clothe ones that I picked up over a year ago.
    Still want to pickup a set of corbeau's but this will do for now.
  5. #8575
    Feb 2014
    St Louis
    What did you do today to your 3/S?
    Helped a local guy with his chrome, 15g, '92 vr4. Started out with the tps being wrong, idle screwed up, and the AEM tru boost plumbed so the Wastegates had no signal. 18psi and 28 counts of knock... :O I'm surprised he didn't blow it sky high, he's been driving it like that for 6 months.
    Fixed the tps and idle, fixed the boost controller plumbing, wired in the wideband to chrome, and ended up at 14psi on pump gas with minimal knock.
    Sent from my iPhone 6s+ using Tapatalk
  6. #8576
    Feb 2014
    St Louis
    O, anddd it had spark blowout. All fixed in a couple hours. The first guy "knew what he was doing."
  7. #8577
    Quote Originally Posted by Beef6 View Post
    Those wouldn't be too hard to restore, they aren't ripped or anything.
    Anyways, got most of my interior in. I need some charcoal upper quarter trims... Mine are for a 3000GT and do not fit
  8. #8578
    Stealth charcoal uppers are hard to find.
  9. #8579
    Loaded her into her trailer to nor the location of the E-track
  10. The Following User Says Thank You to 2fnloud For This Useful Post:
  11. #8580
    Nov 2011
    FL
    Replaced my friend's exhaust
