what Did you break Ryan?
1991 Stealth RT/TT
Broke my crank sensor
Charged the battery xD
I'll be rolling the rear fenders tonight. The new wheels poke out a bit and with the Intrax springs I'm sure it would rub when I hit a bump. Plus if you have ever felt/seen the rear fenders they are actually folded down so the edge faces towards the tire. I started bending that lip flat by hand to make it easier to roll. Looks like it has a bunch of seal filler from factory there which cracked a bit. No clue why they have seam filler in that spot. there are no seams there that I can see. Once iut's rolled I'll have to sand out the filler and repaint the underside of the lip to protect the metal.
Mine rub there with Tein springs and 18X9.5 +30 wheels with 275/35/18 tires. There is just a line on the outer edge of the wheel where that lip touches. I should roll mine too.
Also, my fuel pump seems to have died again. Need to diagnose but when I tried to start it last weekend it had no fuel pressure.
1995 Dodge Stealth R/T Turbo
Got my ps pump off again. Turns out there was a rubber plug I overlooked in the inlet of the pump. That would explain why I couldn't get it to do anything before haha .......
Since I'm already posting, is there anything out there that brings ride comfort up a little? As far as I can tell my car has oem struts or some cheap alternative and tein springs. Just wondering what you guys are using and how it rides. Roads around here are rough
The lowering springs aren't helping ride comfort.
Well I figured that much. I'm looking for some alternatives.
IMO Tein H.Tech springs on new OEM ECS dampers (that are properly working with the Sport/Tour mode) are fantastic.
