Page 834 of 892 FirstFirst ... 334734784824832833834835836844884 ... LastLast
Results 8,331 to 8,340 of 8916
  1. #8331
    I don't bite
    Southern IN
    Built another set of 4gswap mounts.
  2. #8332
    Mar 2014
    x
    St. Louis
    Got the front bellhousing part of the transmission tunnel done. It was a pita! I was really trying to tuck it in close to the transmission and not take up a whole lot of space. It would have been a lot simpler to make a straight forward larger part but i don't like making my life easy. As a side note, the rubberized red paint on the floor is soo annoying! Wire wheel eventually got it clean but now the car has rubber everywhere. Some spots weren't clean enough so welding got a little fugly but it'll be covered up so all is well lol.
    Here it is during the fabrication part. Just resting on the roll of tape but it gives you the general idea of what was made.
    Here it is mounted up.
    Going to be doing the middle part here soon. will be a lot easier
    Project LS3S - '94 Stealth
  3. #8333
    Quote Originally Posted by Jeepkid View Post
    Update: after about two hours of back and forth with the steering wheel (with the car off and then on) I set the car down but still no ps. I've had a ton of bubbles come up the reservoir and even then my wheel never felt jerky when the tires were off the ground. It's smooth when I move it back and forth in the air. My old pump had the flow control valve broken off. I got a new pump and then transferred the valve from another pump on to my new pump. I put it back together exactly as I took it apart. Could my problem be there? Maybe I ruined the new pump lol what do you guys think? I appreciate the help!
    No clue, sorry
    Oct 2015
    Well I'll probably try swapping out pumps with the used one I have here lying around. Hopefully that fixes it. If not then I'll just torch the damn thing 🔥
  5. #8335
    Mar 2014
    x
    St. Louis
    I decided to build the sides first and then the top. I severely lack the fabrication skills to build that in one piece as I'm trying to make a snug fit and nothing is even close to symmetrical with this transmission. Project Binky could pull it off, but i'll stick to just doing one side at a time lol.
    Anyway, here it is, both sides welded in place and waiting for a top. These may look deceptively simple, but i assure you it was a huge PITA. I suppose looking simple means it turned out ok though. All of the crazy bends/cuts/welds are on the floor. Turns and elevation changes everywhere! Very tricky. Tops look like flat pieces but those are also curved in many many areas to fit nicely. I snugged up the carpet to see what's what and it looks like everything will appear about 99% oem. The flap you see near the shifter is for clearance of the reverse lockout solenoid. It will be formed and capped off eventually but for now its just going to chillax by itself up there.
    This pathetic excuse for a picture is where you can see the two sides rolling in towards the center. Making the top part will be pretty straight forward. You can also see the solenoid here and sort of get a glimpse at the differences between the two sides.
    A/C fits! Had to trim the bracket at the bottom just a bit, not much at all, fits like a glove! Still need to find a solution for the heater though. Should be simple enough as there are many slim heater cores to be had.
  6. #8336
    You're doing a really nice job of leaving enough room for comfort going forward, Mike.
    Lotta guys wouldn't think of that.
    And quit denigrating your own work - you're almost qualified for an internship on Project Binky!
  7. #8337
    Rochester Hills, Mi
    That's looking really good! Nothing about what you're doing is easy, props to you for going through with it!
    I'm curious though, and I'm sure you thought about/tried it, but if you took the old tunnel out in one piece wouldn't it be easier to just make spacer panels to raise it up? You'd have to cut a hole for the shifter, but I'd think everything else would line up. Again, I'm sure you're following the path of least resistance, but I'm just wondering why you found that reusing the old tunnel wouldn't work.
    95 Base 3k: 6G74/TT/AWD conversion
  8. #8338
    Mar 2014
    x
    St. Louis
    Thanks!
    Yeah gave that some thought but the design of the old tunnel makes it not worth the effort. It is made of 3 spaced out painted layers metal with undercoat on the bottom and rubberized stuff on the top, wouldn't be of any extra value either if i did use it. The spacer thingies that I would build would essentially be what I created above so making my own top piece makes a lot more logical sense. I can mold it how i would like as well. Thanks again!
  9. #8339
    I don't bite
    Southern IN
    Dropped it off for 10pt chromoly cage build.
  10. #8340
    San Francisco
    Stared at it and sighed.
    Support NG!
