Page 831 of 892 FirstFirst ... 331731781821829830831832833841881 ... LastLast
Results 8,301 to 8,310 of 8916
  1. #8301
    Mar 2014
    x
    St. Louis
    Scrubbed down the engine bay, It was nasty! Didn't take a specific "before" picture but you can get an idea with this older one, nasty stuff everywhere! Used purple power and some pretty stiff bristled brushes (used for cleaning wheels i assume) and scrubbed and scrubbed until it cleaned up.
    before-ish
    After
    Project LS3S - '94 Stealth
  2. #8302
    Sep 2012
    Decatur, TN
    Quote Originally Posted by MDoe8 View Post
    before-ish
    After
    Surprised that more paint didn't come off the rail there under the brake booster and master. So often people are careless when they top it off and end up spilling brake fluid on there.
  3. #8303
    Mar 2014
    x
    St. Louis
    All that paint damage is under the battery
    Going to repaint the engine bay anyway but that's still no bueno.
  4. #8304
    Sep 2012
    Decatur, TN
    Indeed. I tried to sand mine, but paint just kept peeling off and clogging the sandpaper. Eventually gave up and put a wire wheel on an angle grinder to power through it.
    Today I didn't do much, thought I was getting better and could finish cleaning up my garage in preparation for dragging a shell here..So very very wrong. Ears feel like they need to pop and my sense of balance is nowhere to be found.
    As an added thought, anyone ever hang a 3S hood on the wall? I'm thinking just bolting a 2x4 across the hinges and then running it into the studs for the wall with lag bolts is probably the easiest solution, but open to other suggestions.
  5. #8305
    Oct 2015
    My car had been leaking ps fluid since I bought it. It was hard to tell where it was coming from. A few weeks back there was a huge puddle of ps fluid in my garage. Looks like a seal on the pump went out as it was pouring out from around the pump when I tried refilling it to identify the leak. Finally got around to working on it yesterday. I didn't realize just how little room there was to work around in these things. It's been a slow process but I'm hoping to have it done today.
  6. #8306
    Tried my RPS light flywheel out for the first time. I have no idea why people bitch that these are hard to drive. Grandma could drive it with the spec 4+ in it. If I didn't tell someone they'd probably not realize it wasn't a stock flywheel. They might think it was a stock clutch. It just revs easier and feels a little smoother. It doesn't want to die at all taking off, very easy.
  7. #8307
    Mar 2014
    x
    St. Louis
    It's the 3s community. If a turbo requires more than 3000 rpms to spool or the clutch is 2 lbs heavier than stock...bitching occurs lol.
  8. The Following 2 Users Say Thank You to MDoe8 For This Useful Post:
  9. #8308
    Sep 2012
    Decatur, TN
    Someone finally said it.
    Sent from my SCH-I545 using Tapatalk
  10. #8309
    I have come to realize over time that 95%+ of naysayers on the forums have never actually tried the parts in question. You have to try it for yourself.
  11. #8310
    Rochester Hills, Mi
    I had a lightweight flywheel on my NA for a while. I noticed that if I accelerated hard and then pressed the clutch the IAC wasn't fast enough to catch the engine and it would die. It did let the engine rev faster though, I learned to drive it like that anyway. Then my POS SPEC clutch blew the spring cages out and ruined the flywheel. I now have a lightweight steel flywheel on my TT and it is best of both worlds for me. Each car is different, sounds like yours behaves a lot better.
    95 Base 3k: 6G74/TT/AWD conversion
