Decided to move my car a couple feet, since it's been sat in the same place for about a year...
Warped crank?
Doing some drivability and mileage tuning on the AEM. 80 mph cruise is getting dialed in.
Sent from my ONE A2005 using Tapatalk
Now installed in the cluster. Took my cues from the lcdbc peeps.
Acquired this beast today for the awesome sum of free. I'm excited as this was one item that I didn't have for my garage.
3hp, 9.7scfm @40 psi, 30 gallon.
Project LS3S - '94 Stealth
Holy crap! LS swap?
