Page 821 of 892 FirstFirst ... 321721771811819820821822823831871 ... LastLast
Results 8,201 to 8,210 of 8916
  1. #8201
    This is an interesting find. My Bell SMIC's (4.5x8x8.1) flow 683cfm each so that's a total of 1366cfm. I just looked up a Treadstone TR1245 and here's the specs on it. 4.5" core, 1469 CFM flow rate, 1000hp efficient, 1.5psi drop
    Very interesting to say the least. Just might test it out myself when I make a set for that customer.
    Quote Originally Posted by MDoe8 View Post
    Interesting you say that. I want to avoid an FMIC perhaps but i've got a powerful setup as well so maybe they won't handle it. Twin 57's maybe stick with pump gas though so roughly 700hp. They should still be ok for that no?
    "Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    ----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
  2. #8202
    Mar 2014
    x
    St. Louis
    Whenever money is being kind to me i will definitely be hitting you up for them if they prove to work for higher power levels. Would be with 2.5" outlets. I don't have any doubt that they will. The 300zx people push twin smic's over 700hp. LS people get very very high power with twins as well. Here's Z1's 300zx kit
    https://www.z1motorsports.com/interc...et-p-6606.html
    Project LS3S - '94 Stealth
  3. #8203
    Feb 2014
    St Louis
    I believe piping size and airspeed can have a huge effect. I need to pull out my maximum boost book......
    Sent from my ONE A2005 using Tapatalk
  4. #8204
    That would be very difficult getting a 2 1/2" pipe down on the drivers side without some difficulty. Same with routing it under to the Y. When I start to look at doing this I can tell better.
  5. #8205
    Sep 2012
    Decatur, TN
    Quote Originally Posted by oohnoo View Post
    Story is a weeeeebit different with an LS engine in the bay though
    That said, the real concern would be heat soak, not sure at what point that becomes an issue for folks. Unless someone who road courses is going to go out there and flog the shit out of their car with IAT probes throughout the IC system, it's hard to say. I'd wager a TD05 or a T3/T4 car is going to be more efficient anyhow vs a TD04 car as far as boost vs heat generated. Would also need to account for whether or not the turbos on any car are in their efficiency zones.
    I'd say for the average street car or drag car, you honestly may not notice a difference between the two. I suspect it'd likely take multiple back to back to back runs on a drag strip or autocross before most would start to see actual effects of heat soak.
  6. #8206
    Jun 2011
    Sweden, Gothenburg
    I think the smics would flow well enough. Only thing we need is proper ducts for the bigger smics. I think it's extremly important. Otherwise half of the air just escapes through the sides of the smics. With ducting The air has nowhere to go but being forced through the smic.
    Proper designed ducts in fg or cf like this I mean
  7. #8207
    When I designed my large Bell SMIC's I made sure they retain the stock air ducts.
  8. #8208
    Feb 2014
    St Louis
    Mmm carbon
  9. #8209
    Mar 2014
    x
    St. Louis
    Didn't ray make his big dr750 power numbers through the stock intercoolers? Obviously that doens't take into account multiple street pulls but the flow is there at least.
    If i end up going side mounts I may make my own ducting as I will have a 99 bumper and it seems like i will be able to steal more air from the side vents than in a 97 style.
  10. #8210
    He never had stockers int here. At first he had the Almo smic's in there but never liked them. He upgrade to my Bell SMIC's since then.
