Page 805 of 892 FirstFirst ... 305705755795803804805806807815855 ... LastLast
Results 8,041 to 8,050 of 8916
  1. #8041
    Beautiful car Fast, very well deserved.
  2. #8042
    St.Louis
    Quote Originally Posted by Primus101 View Post
    Are you running a hydraulic or solid tensioner?
    This was an engine that I pulled out of a wrecked 94 I purchased to part out. The heads were re-manufactured and I believe it was probably the shops shoddy work that was the cause of the gouges. Over half of the valve springs were installed upside down and the cam caps were over-torqued IMO. I have a solid tensioner from Ninja and a power Kevlar belt I want to use on the motor when I am building it, but I am debating just using a hydraulic tensioner with the Kevlar belt.
  3. #8043
    GREASE BUNNY
    VA
    I thought about my 3S today....as I do everyday
    I think about how I need to finish breathing life into it.
    Yea
    That's what I did today
  4. #8044
    Aug 2015
    north carolina
    i put my stickers on my 91 TT rear windshield from blue ridge gathering. couple from the souvenir shop at deals gap and the brg logo. also put some ninja performance decals on there also
  5. #8045
    Mar 2014
    x
    St. Louis
    Quote Originally Posted by Granny View Post
    Yea
    amen to that. Every day occurrence for me as well.
    Project LS3S - '94 Stealth
  6. #8046
    Never finishes any verified
    Wake Forest, NC
    Pulled the transfer case to fix a leak. input seal had a kink so had to put a new one in. Took the casing all apart and ran it through the blast cabinet to clean it all up while waiting on the seal to come in. painted the center section and clear a the rest to help keep it clean. Got the seal in today from Ninja, all back together and should be able to reinstall it tomorrow.
    Then I'll be pulling it out of the garage and pulling the trailer in. Going to try and knock out some work on it before it rusts to death sitting outside...LOL
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  7. #8047
    JNS Engineering verified
    San Jose, CA
    Any pics Greg? I have a similar leak on my TC.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  8. #8048
    Wake Forest, NC
    Here is the leak in the input seal if that is what you were talking about:
    I kept thinking it was from the rear turbo drain or something above it. Finally pulled the x-case and found that little crease in the seal.
    No pics of it all back together. Nothing special really. Clear coat just helps keep dirt and crap seeping into the aluminum's pores and staining it.
  9. #8049
    yeah takes a couple hours to fully clean and re-seal the t-case, but worth it.
  10. #8050
    San Jose, CA
    Yeah I thought mine was the transmission but the fluid wasn't red like the MT85. That seal damage is pretty subtle in the pic.
