Page 803 of 892 FirstFirst ... 303703753793801802803804805813853 ... LastLast
Results 8,021 to 8,030 of 8916
  1. #8021
    I did a little bit of this and a little bit of that
    Its come a long way since I posted this pic
  2. #8022
    Member
    Arvada, CO
    installed the charcoal seat cover for the rear seat bottom finally. its not perfect but its better than having that piece be the only part of the seats that is still cream colored.
  3. #8023
    Sep 2012
    Decatur, TN
    You seem to be missing a camshaft from each head sir
    Looks very good, jealous. Tell us what it's like to have a reliable engine?
  4. #8024
    I think you need to be asking him about transmissions
    St.Louis
    Tore into my front tt head and found one cam journal was gouged/ scored.
    Can the head be saved? I have some 92 TT cams to swap in.
  6. #8026
    I've seen people run a LOT worse cam journals than that. I personally feel that the cam itself is scrap though, it looks really rough.
  7. #8027
    Sep 2012
    Decatur, TN
    Would think getting just one set of journals line honed would be fairly cheap (probably less than $50 but that's a guesstimate) however I think throwing another cam in there would just eat it up like your current one.
  8. #8028
    I've never seen a machine shop that would let you line hone just one set of journals... but putting another cam in there would be fine. The journal is soft aluminum and the cam is hardened...
  9. #8029
    No Show NG11 Not Verified
    Mesa, AZ
    This was last night, but I put I put some new headrests in out of a Starion.
    Your 1993 Mitsubishi 3000GT SL is one of 4310 that received VIN numbers. Based on the order of the serial numbers, your car was the 2685th out of the 4310 that were made that year.
  10. #8030
    Lets see, I took my timing belt back off, took the cam gear off, and the backing plate, just so I could put a bracket in I forgot to put in, then put everything back together. Cleaned up the alternator and ended up putting a coat of paint on it. Cleaned up my tensioner pulley and put a coat of paint on it.
    All I really need to do to the engine now is get the valve covers painted and on, and get over to my cousin's place and attempt to hydrodip the intake manifold.
