Page 791 of 892 FirstFirst ... 291691741781789790791792793801841891 ... LastLast
Results 7,901 to 7,910 of 8916
  1. #7901
    and a 95 too!
    April 2005
    Door Peninsula
    Are you sure the knock sensor isn't bad?
    Replaced it with a new one last year during the VSS job. I'll get a log and post it up. Thank you for your help!
  2. #7902
    Jun 2011
    Sweden, Gothenburg
    Got started on this fg hood that needed some work.. Needs some epoxy repairs in a few spots. And need to figure some way to get the main hood latch on there
  3. #7903
    Feb 2011
    Scottsbluff, NE
    A new sensor doesn't mean there aren't wiring issues in the main harness. I've had several issues in the main harness myself.
    1995 Dodge Stealth R/T Turbo
  4. The Following User Says Thank You to DK77 For This Useful Post:
  5. #7904
    Bought a new motor for it...
    Actually its for another car. But I did put new battery terminals on the vr4 last night and did some tuning. I'll be messing with launch control more tonight to try and get everything dialed in before the track this Friday.
    Built motor, DR750s, AEM and Meth
    http://www.802projects.com
  6. #7905
    Been restoring my subframe for a couple weeks now, all new pressed bushings, grinding, paint, coilovers, adjustable control arms, aws delete, brake lines, rotors, pads ;o so much stuff. Once this is done i'll be starting to get parts for my 19T build
  7. #7906
    Mar 2014
    x
    St. Louis
    Busted out the orbital today rather than hand polishing. Paint "restoration" on an old faded car is so freaking fun and rewarding!
    Project LS3S - '94 Stealth
  8. #7907
    St.Louis
    Well I Am getting ready to pull the 4 bolt motor out of the 94 parts car I bought. Ive been ordering gaskets, pumps, and parts to rebuild this one and drop it in with 9b's and all my bolt ons. Going to just do a mild stock build for street fun and reliability.
    I think i have found 2 potential buyers for my built 2 bolt block so im pretty happy to get it moved out.
    More progress has been made on pulling the motor. The wiring harness has been pulled from the interior and the only things remaining to be disconnected are the fuel lines and the PS lines.
  9. #7908
    St.Louis
    Getting my DSM SMICs ready to send to Bob to have them converted. Completely cleaned the inside and out of the cores.
  10. #7909
    Member
    Arvada, CO
    Put a new battery in it. the old one would be completely dead after letting it sit for 2 weeks.
  11. #7910
    RTBOOST verified
    Florence, Wisconsin
    Quote Originally Posted by Bloodlust182 View Post
    He does great work!! Mine turned out looking very nice & I intend to powder coat the chambers & pipes & use some EW radiator paint for the fins to give them an OEM appearance.
    And again not for my car, but I got some more front valve covers stripped & ready for some powder.
