Page 781 of 892 FirstFirst ... 281681731771779780781782783791831881 ... LastLast
Results 7,801 to 7,810 of 8916
  1. #7801
    Mar 2014
    x
    St. Louis
    I dig the spacer cover thingermajobber
    Project LS3S - '94 Stealth
  2. #7802
    Man vs 3/S verified
    Kingston, WA
    Went from junk yellow headlights to this
    Sanded all the factory clearcoat off, polished, 2 coats of premium PPG clearcoat. Need to wetsand and polish a final time. They look soooo much better.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  3. #7803
    I don't bite
    Southern IN
    Swapped in a welded center diff Friday. Stress tested it last night. It passed Ran errands around town with it today. One race.....with my wastegate dump tube when it came off and raced me down the road! Time for lock-tite and and/or through bolts w/lock nuts. (Living the 4cyl, no balance shafts, solid mtr mount Life)
  4. #7804
    How bad is the 4G really without the balance shaft? My cousin is going to eliminate his in the coming months when he does a few other needed things.
  5. #7805
    I don't bite
    Southern IN
    What did you do today to your 3/S?
    Very noticeable on the 2.4 with solid mounts. 2.0 should be less. I also have a monster side exit exhaust that adds some vibration. And big kelford cams. It all adds up to some vibes, shakes and rattles unless you are wide open. Then it all makes sense and everything is right in the world
    Stock cams and full exhaust, it vibrated and rattled but seemed much tamer. Could be perception.
    2.4 with balance shafts...purred.
  6. #7806
    That's kind of what I figured and had read elsewhere, just was wanting firsthand experience. I think he plans on sticking with stock mounts so it shouldn't be unbearable. He's been in my Stealth with the solid mounts so I am sure he will be able to deal with a balance shaft deleted 4G63
  7. #7807
    Man vs 3/S verified
    Kingston, WA
    Got these mounted on a new set of AMR's
    Headlights finished. Look pretty good. Not 100% like new but I havent hit them with a DA and compound.
  8. #7808
    JNS Engineering verified
    San Jose, CA
    Slapped the EVO MAF and catalytic converter back on and passed smog testing. She measured 58 ppm HC at idle where 100 is the limit and 20 ppm HC at 2500 rpm where the limit is 130. So plenty of margin with just the main cat and no precats. I almost went with the Z06 + MAFT but it doesn't have the CARB certification like the K&N on my EVO MAF has. May have been fine though I didn't have it running right yet.
    Now back on jackstands to swap the test pipe back in
  9. #7809
    Never finishes any verified
    Wake Forest, NC
    Had an exhaust leak that was driving me nuts on the down-pipe. ordered new gaskets, got them in and still leaking. I couldn't figure out where it was coming from.... Ended up taping off one side of the exhaust and sticking the shop vac on blow into the other side. Pressurize the system and found the leak spraying soapy water on the connections.
    Also got he rear end all back together after doing some painting and re-tinting the rear tail lights. I used a satin clear on the lights afterwords to dull them down to match the finish of the car. Need to do the same to the reflectors red bar.
    Took her out for a test drive and the damn Ac/Alt pulley is squealing. So I need to order a new one. I have fought with that old one long enough so it's time to bite the button and drop the $120 for a new one.
    Once the new pulley gets here I'm also going to set the adjustable cam gears back to zero. On the test drive the car cruised like shit. Almost stalled in some gears if the RPM's got under like 3k and the engine is just really choppy until about 3500-4k. She pulls great through just horrible and cruising. I'm just not about to try and drive it like that at NG in a couple weeks...
    Also note swapping out the cams and adding in the adjustable cam gears also did NOT fix my decel exhaust popping issue.... So I have no clue what is causing it. Timing is dead on, new plugs and coil pack. IDK So you can call me Poppy at NG!!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  10. #7810
    Sep 2012
    Decatur, TN
    Wouldn't exhaust popping on decel generally indicate too much fuel being dumped at that point? Between that and stalling out at cruising, definitely sounds like some kind of boost leak to me. Assuming you have a wideband hooked up and are monitoring AFRs?
