Page 765 of 892 FirstFirst ... 265665715755763764765766767775815865 ... LastLast
Results 7,641 to 7,650 of 8916
  1. #7641
    Feb 2011
    Scottsbluff, NE
    That list seems so simple, but I know otherwise
    1995 Dodge Stealth R/T Turbo
  2. #7642
    Devoted Darkling
    Is a 10 second capable street car so much to ask for???
    2017 Chevy Volt: Daily Beater - More range, more savings!
    2015 335i Sedan M Sport: Replacing the 2007 335i... may it R.I.P.
    1994 3000GT VR-4: 12.835 @ 109.40 (stock injectors...) still have it... for now...
    2007 335i Sedan: Totaled while sitting at a red light...
    1997 Supra TT: Gone to the land of the Red Wings
    "The world might end the night might fall :: Rain on down and cover us all :: And drown us with the burdens of our sins" -- Shirley Manson
    "I'm very, very famous. Not a lot of people know that." -- Geoff Achison
  3. #7643
    Feb 2011
    Scottsbluff, NE
    Absolutely not, but having one myself, that DR750s bullet includes a lot of other fun stuff
  4. #7644
    Mar 2014
    x
    St. Louis
    Inner tie rod extensions on and welded active exhaust open and bolted the exhaust on.
    Project LS3S - '94 Stealth
  5. #7645
    Feb 2011
    Scottsbluff, NE
    So this is gonna look and sound (relatively) like a stock 3S until you pop the hood or open the cutout then?
  6. #7646
    Mar 2014
    x
    St. Louis
    pretty much. Not sure how it will sound as even the stock exhaust isn't the quietest. We shall seethough.
  7. #7647
    Quote Originally Posted by Ange View Post
    Cleaned up my eurospec headlight washer tank and it's parts. Looks almost new now. Going to use it as an intercooler sprayer instead.
    Good thing I can just reroute the nozzles with the original hoses and use the headlightwasher button for my IC spray ^^ Might get new nozzles that has a wider spray that's it
    Attachment 7888
    This was in my build plans as well. After some math, and speaking with others running meth it does not hold enough for my needs. One things I had not looked into with this was if it had a baffle to prevent the liquid running to the other side starving the engine of meth in corners.
  8. #7648
    Dropping off my REtro-Spec side splitters to be line-X coated for durability.
  9. #7649
    Jun 2011
    Sweden, Gothenburg
    True. Running out of meth in high boost could be real bad :S Maybe safer to build forged bottom before thinking about that stuff.
  10. #7650
    Hood pins mostly installed. Ignore the hand prints.
    Built motor, DR750s, AEM and Meth
    http://www.802projects.com
