Page 755 of 892 FirstFirst ... 255655705745753754755756757765805855 ... LastLast
Results 7,541 to 7,550 of 8916
  1. #7541
    I don't bite
    Southern IN
    Is the fastest four cylinder 3s that can carry four people.
    I should sig that with "New record!"
  2. #7542
    Sep 2012
    Decatur, TN
    And then start selling the stuff for other people to do for well over market value.
    Videos just got done uploading to YouTube. Bout to throw them in your thread.
  3. #7543
    Sep 2012
    Decatur, TN
    Here is the company I used: United Metal Finishing, Inc. » Surface Treatments ? Electroplating ? Anodizing
    They can be a little bit of a pain as they usually deal only on commercial stuff. They wanted me to set up an account and draft the money from my bank. Took a bit but I finally convinced them to take a check. Filled a large flat rate box full of hardware I cleaned in the blasting cabinet "Which took forever to blast a bunch of nuts and bolts".
    Thanks! I'll give them a ring once I get the rest of this stuff squared away. Honestly, a lot of the chassis bolts are probably just going to be getting replaced. The amount of rust and corrosion on some of these is mind boggling.
    Today, I unloaded the trans and cleaned it off. Probably just going to leave it on the rolling cart for now, this bastard is heavy to have to move around on it's own. We didn't get home until about 1am, which is late for a couple who normally goes to bed around 10-1030.
    Probably not going to do much else to the car stuff today. Trying to organize and clean stuff up, try to make room to fit everything. I've sold enough stuff (and reassembled enough stuff) that I now have space on my shelves in the parts room to fit some of my big tools that I don't use often enough to justify cluttering up the garage with. That should help. Need to get in there and start seriously cleaning stuff out. This lease runs out at the end of June and I should probably get packing this stuff up as I don't plan on staying here. Need to get the car ready to go onto a tow trailer.
    I'm assuming rear subframe and trailing arms, front steering rack cross member and control arm, steering knuckle, hubs, the axle pieces to keep it from destroying the hub, and then probably put the OEM ECS struts back on for better ground clearance than the coil overs.
  4. #7544
    Bought it some tires to try out. Should be worth 4-8 seconds a lap.
  5. #7545
    STL, MO
    Nothing till next Friday :/
    1991 Stealth RT/TT
  6. #7546
    Sep 2012
    Decatur, TN
    Broke some parts I had hoped to sell when I bumped the hood (not installed) and it fell over onto some headlight parts. I then screamed obscenities and had a beer. Also, looked at some new recipes with bacon in prep for BRG this year. Baconhouse rules!
  7. #7547
    Prepped for valve stem seals tomorrow!
  8. #7548
    Never finishes any verified
    Wake Forest, NC
    I picked up this bad boy today to haul my car to NG and where ever else. No more having to rent Uhaul trailers are praying I make it without loosing a wheel!!
    82" x 18', Tandem Dexter axles (3500 lb each), brake on one axle, dovetail, wood floor, heavy duty fenders/step, bearing buddies, Stow-able 5ft ramps, LED Lights.
    Picked it up brand New for $1,900.00 out the door!!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  9. #7549
    $1900 out the door!!!! That is a deal.. I picked up Wingnut's (same size, no dove) and he paid around 3k...
  10. #7550
    I wanna deal like that!!!
