I dig that metallic graphite. very clean
Project LS3S - '94 Stealth
I was also going to recommend soda blasting but it's not a guarantee to get it off. If you do try it, I find it works really well through a normal sandblasting gun. I bought the $20 siphon gun at tractor supply and just stuck the pickup tube in the box of baking soda. Works way better than the diy soda Blaster that uses a tube and a blow gun. I recommend doing it outside in a storage container so most of the baking soda stays contained, once enough piles up in the container, you can stick the tube in it and reuse it. You'll go through a shit load of baking soda so it's good to try to reuse some.
Thanks for the suggestions. If I can't get it off with a wire wheel then I'm going to leave them and just lap them as is. I should have just sent them to the machine shop to begin with and I'm just tired of dealing with them. I have a sandblaster and homemade cabinet but I'm sure the black diamond stuff would damage the valves.
fragged my rear diff....with my measly N/a engine.
Impressive to break a diff n/a lol. Must have had some fluke thing happen to it. Bummer!
Thanks! Yeah trans tunnel took a lot of cutting for sure. Need a bit more now that i raised it and pushed it back. Will have pictures of that soon as thats one of the things on the list for the near future.
No clue what happened. I was driving through some snow in the pick n pull parking lot and heard a loud click. Car doesn't drive differently until 55mph, then there is a noise that sounds like a wheel bearing going out. It is weird though as there is a whoomp sound, but it sounds like it is twice per revolution. Oh well, going to pull the diff apart to inspect what happened when I have some time. School and working 2 jobs is killing meh. I suspect a spider gear cracked or maybe the VCU took a shit.
