Page 735 of 892 FirstFirst ... 235635685725733734735736737745785835 ... LastLast
Results 7,341 to 7,350 of 8916
  1. #7341
    Feb 2015
    I received my new shift boot (but car hasn't arrived so can't install it yet!).
  2. #7342
    I don't bite
    Southern IN
    Received my second AEM datastream gauge.
  3. #7343
    I don't know, I think the 96 wing makes the rear a lot more aggressive, as if the car is ready to launch, but whatever. I used to like the combat wing. Trying to be a lot more subtle now. I don't want gawks everywhere I go.
    This. The 96 wing may not be a huge difference, but the difference is definitely there. When I first put mine on way back on 04 I was at a meet and I had several people do double takes because of my spoiler, and a whole conversation was started over it several times over.
  4. #7344
    Dec 2011
    Iowa
    While waiting on the machine shop to finish cleaning my block and checking out the crank, I have my heads torn down and cleaned and will be reinstalling the valve train this weekend. When I first disassembled everything I had all the valves marked so I knew what valve went to what guide. I decided to throw all the valves in the bucket of chem dip (after a long day) to clean then and so they are no longer organized. Will I be ok just lapping the valves, or will I need to send them to the machine shop since the valves will no longer match with the original guides and seats?
  5. #7345
    Sep 2012
    Decatur, TN
    Ugh..working on heads last night. Realized that the machine shop that cleaned them removed a few plugs and never reinstalled them.
  6. #7346
    West MI
    Cooked a y-pipe gasket on the woodstove
    92 3000GT VR4
    Matt
  7. #7347
    Member
    Arvada, CO
    It was yesterday but I finally installed the solid shifter bushings, both the base and cable ends. only problem is that 1st gear is not stiff. its smooth, no notchiness or "walls" just kind of...gummy. I think the cable end bushing might be binding slightly when going into first as it will have the most angle from the cable mounting bracket on the trans.
  8. #7348
    Quote Originally Posted by jras312 View Post
    Check the valve guide play and lap the valves to the seats.
    Oct 2013
    SW Michigan
    Quote Originally Posted by sublime_whatigo View Post
    Haha so that's how you fixed it
    What goes with that? A Red or White wine? Or is it Bells?
  10. #7350
    Sorry. 99 just makes more horizontal lines on the back of a stealth. And the angles just don't flow with the curvy lines of the stealth either. I don't even like wingless....but a wingless stealth > stealth with 99 wing.
