Page 727 of 892 FirstFirst ... 227627677717725726727728729737777827 ... LastLast
Results 7,261 to 7,270 of 8916
  1. #7261
    Twin Turbo verified
    Melbourne, Australia
    Quote Originally Posted by box View Post
    Bugger. Can you feel the wear with your finger nail? Is that cylinder 1?
    no. 6. You can just very slightly feel it with your fingernail. You can't feel it with your fingertip. I have some spare stock pistons so I'm considering removing the sump. Pushing out no 6 and inspecting. Replace with another used piston.
    Waiting install
    Build Thread
  2. #7262
    Never finishes any verified
    Wake Forest, NC
    I've been working on this the last couple of days. Hope to have the new wing and rear deck repainted in the next 2 weeks. Shop has been busy so I don;t have a lot of free time to work on it. Little bit here and there...
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #7263
    Combatalicious!
  4. #7264
    Sep 2012
    Decatur, TN
    Supposed to be getting a call Monday from Eastwood about the regulator. Need to pick up some heavier wire for the cart I want to make. Doubt this .023" wire could do 1/4" thick, likely pick up some .030" for it.
    Alternatively, *might* be able to grind it and make a few passes.
  5. #7265
    RTBOOST verified
    Florence, Wisconsin
    I swapped out another broken connector on my currently installed engine harness, stripped & powder coated the replacement transaxle-to-engine stay bracket I got from Erron (thanks again!!) & also got the shifter cable bracket in some high-gloss black, too. Oh, & I've been cleaning/tumbling some of the non-damaged bolts & miscellaneous fasteners the past couple days.
  6. #7266
    Twin Turbo verified
    Borrowed an engine stand from Paul/TUFFTR. Going to buy the 2nd gen engine off Throwawayfool/John Howe and rebuild it instead since it comes with a full set of new pistons, rods and rings and being from a 94 model has a forged crank and 4 bolt girdle. I had planned to buy a 2nd gen engine and rebuild it then drop it in once complete. This has just moved that forward somewhat. Just unfortunate timing since I have no money
  7. #7267
    Mar 2014
    x
    St. Louis
    just leave it like that
    Project LS3S - '94 Stealth
  8. #7268
    No Show NG11 Not Verified
    Mesa, AZ
    I ordered some parts.
    Your 1993 Mitsubishi 3000GT SL is one of 4310 that received VIN numbers. Based on the order of the serial numbers, your car was the 2685th out of the 4310 that were made that year.
  9. #7269
    Drove it around the block. Definition of self control, not even one drift or burnout happened.
  10. #7270
    Jan 2011
    Not really today, but recently had it in for a quick dyno run and to tidy up the timing maps. 50kms of dyno time later, I've now got a center diff that has had an absolute meltdown. Same place I normally use, different tuner (incidentally the owner of the business). This is what the sump plug looked like
    This is what the fluid looked like
    What could possibly have gone wrong? ~10,000kms, 1 dyno tune and 2 trackdays since 2nd gear syncros were done, all has been well until now. That fluid is approximately 3,000kms old.
