Page 722 of 892 FirstFirst ... 222622672712720721722723724732772822 ... LastLast
Results 7,211 to 7,220 of 8916
  1. #7211
    Sep 2012
    Decatur, TN
    Wire a switch to an outlet. Done.
    I rent, so don't want to do anything like that. Landlord is a bit of a stickler.
    Looks good E. Come cruise over to TN, I'll help you figure an exhaust out, think I may have a folgers can laying around we could weld to it..
    I know they shouldn't be run this way, but I've ran them with a 3 to 2 prong adapter and then a light socket adapter. The bulbs fire off a little slower than normal, but work OK.
    I'm leaning towards going that route, but may just deal with having to use the pull chain. Don't like the idea of using a system that is supposed to be grounded in that fashion though.
    Wouldn't be terribly necessary but when they built it, they put the freaking lightbulb right behind where they mounted the garage door opener...so half the garage gets little to no light.
    I have the fixtures hanging from the garage door tracks ATM.
  2. #7212
    FWIW, I have had a few 3 prong plugs where I literally snapped the 3rd prong off, both on purpose, and on accident and still used it with no issue.
  3. #7213
    I have had 4 fluorescent lights connected in the garage using a light socket adapter with a 3>2 prong adapter for the last 6 years or so. Always planned on wiring them in correctly but it worked without issue.
  4. #7214
    West MI
    If the lights are high enough where you can't reach and touch them its not much of an issue. If your lights are on GFI (not common) or you can put them on a gfi circuit it's completely up to code. Some really old florescent lights needed a ground to light properly but other than that the ground won't affect lighting, its mostly to protect you.
    Also you can buy these
    92 3000GT VR4
    Matt
  5. #7215
    Mar 2014
    x
    St. Louis
    Nice familyman! The exhaust is....subtle
    Today I did the same thing i've done for the past month....absolutely nothing Haven't had much motivation to finish up the steering arms so i just sit around and do nothing instead.
    Project LS3S - '94 Stealth
  6. #7216
    Quote Originally Posted by MDoe8 View Post
    Can relate...
  7. #7217
    I don't bite
    Southern IN
    The tip is statin black; that's subtle right? I'll work on something more subtle at some point but want to hear each blip blop for now.
    Speaking of steering....There's a true manual DSM steering rack hiding under there now. Need to get it to my buddy's so he can align it. Will post details after I confirm we can get it aligned. Also need to pull steering wheel, set clockspring and recenter steering wheel. I botched up the centering of the steering rack on installation so my steering wheel centering is way off.
  8. #7218
    Well I hit 17psi today in the cold any I don't think I have enough fuel pump. I'm running 19hls, pretty sure the walbro is running lean.
    Sep 2012
    Decatur, TN
    If so, should be showing up either on your wideband gauge or in your logs. A 255 Walbro should support 500awhp pretty comfortably before being tapped out. Even with the 19T HLs, not sure how close you are to that yet at 17psi. I'd look at AFR to see if it's happening or not and make sure that it's not IDCs that are running out. If the 255 really is tapped out, upgrade to the 416.
  10. #7220
    Never finishes any verified
    Wake Forest, NC
    I'm guessing your running out of flow. as Sergechronos said check your IDC's, if they are high then bump your base fuel pressure up some and adjust your tune. that should give you more fuel to work with without needing to change out your pump. On my 10: engine I pumped my base fuel up to like 55 psi so my 360cc injectors could flow up to 450cc when I needed the extra fuel.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
