Changed my wheels, checked my brake pads, they are really thinOh well, 160 more dollars to Supercar for some new ones tomorrow!!
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
Bought the ABS and AWS delete kits and a new front rack.
nice. just beware, if you do get coilovers, the AWD conversion severely limits clearance between the rear shock and the driveshaft flange. i might have kept my stock suspension if my tires weren't getting scored by the fenders. coilovers helped raise the rear enough that it was no longer a problem. if you stick to the stock width tires, it probably won't be a problem though.
I'm probably sticking to a stock type suspension at first. I do have some intrax springs but I have no idea how they will work with the angle the rear will be after the conversion. I wonder if it will drop it too far?
i wouldn't use springs on the rear. the rear will sit MUCH lower. if you want, use springs on the front, but that's it. i think when i got mine done, i barely had 2 fingers gap between tire and fender. on stock springs, that's NOTHING. lowering springs, while stiffer, would have done nothing to fix that--and would have made it worse.
Removed old alarm system. Tried to trace out a bad wire without removing my dash.. I think I need to remove the dash now.
Got towed home in it...
I put my lip on , smoked a cigar and put in a support email to aem.
Hacked up stock maf to use just baro and iat.
Installed giant 9" by 4" air filter.
Got decent speed density tune on wastegate boost
Sent from my DROIDX using Tapatalk
Put the battery charger on the Stealth after sitting a month. A guy stopped by wanting to buy it. I said I may after taking the Borla exhaust and wheels off of it. Drove it about 20 miles and parked in the garage. Putting a new starter on it and checking the TC case fluid.
