Page 692 of 892 FirstFirst ... 192592642682690691692693694702742792 ... LastLast
Results 6,911 to 6,920 of 8916
  1. #6911
    drives with Drivers' gloves.
    Maryland
    Figured out my flash ecu has the 02 sensor wires/jumper swapped internally. Swapped the wires on my boomslang harness for front and rear 02 as well as replaced both older 02s with fresh Densos. And all is good. Now I'm just hoping I can make it work nicely with my ARC2 - I'm going to give it a good effort.
    Got some fresh looking TD04 DNP 02 pipes and BC 264s in the mail.
    Made a wire harness for my SSI-4 to pull in my 3x AEM gauge's output into the innovate log chain I already have with the other 3x Innovate gauges.
  2. #6912
    Never finishes any verified
    Wake Forest, NC
    Blank you say?
    Yeah, that is a blank switch on bottom. Looks like you converted it for something else.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #6913
    facepalm.
  4. #6914
    One fix at a time verified
    Kansas
    I must have done mine the hard way because I used that blank button for the LCDBC rotary knob also but it took forever to modify a 1st gen set with the fog light to work right. Fitting the little board in there and also making the feel of the rotary knob work was what took the most time. I probably complicated things.
  5. #6915
    Sep 2012
    Decatur, TN
    You own a 3S, comes with the territory.
  6. #6916
    The dummy knob popped right out, ground some off, ground the bottom of the dummy knob to make it thinner. Used cutting board material 3/4" x 3/4" sanded it down to about 1/4" thickness and glued it in place.
  7. #6917
    Mad JDM Tite
    STL
    Get to pick up my car from the body shop tonight, Happy Halloween to me
  8. #6918
    Sep 2012
    Decatur, TN
    Installed FIC2150's, new injector connectors, and tucked the injector wiring.
    So far I can't get them to idle as well as the PTE 1000s (which are for sale; set of 6). I'll keep working on it. Haven't tried playing with injector advance yet.
    FIC2150s high z or low z?
  9. #6919
    I don't bite
    Southern IN
    High z. Had to richen idle. Didn't try lower fuel pressure to raise IPW.
  10. #6920
    I thought it sounded a little too good to be true to achieve a stoic idle with 2150s.
