Page 689 of 892 FirstFirst ... 189589639679687688689690691699739789 ... LastLast
Results 6,881 to 6,890 of 8916
  1. #6881
    I don't bite
    Southern IN
    What did you do today to your 3/S?
    Was late when I got home after a long day of travel and wasn't thinking clearly. Should've taken box to the garage instead of leaving it in plain sight! At least it's only the clip that's missing and not an injector. Although he did take one out of the ziplock bag. Can't blame him. They do look nice and I couldn't wait to touch them either
    Edit: found it. Back in business.
  2. #6882
    Sep 2012
    Decatur, TN
    Quote Originally Posted by Unlogic View Post
    Thanks!
    I'm ordering one of those right away.
    Some of the tools needed to properly rebuild trans:
    7mm(5sp) allan socket, snap ring pliers, 10mm, 12mm, 13m, pick, very small flat blade, Punch,
    hammer (metal and soft plastic dead blow), Fine/Sharp edge bearing
    separator (OTC (1123) Bearing Splitter - 1/2" to 4-5/8"), Fine edge Race
    puller (Kent-Moore PN: DT-47865) and Slide Hammer (OTC 4579 9-Way
    Slide Hammer Puller Set)
    And a 20 ton press.
  3. The Following 2 Users Say Thank You to sergechronos For This Useful Post:
  4. #6883
    West MI
    Did a 60k over the weekend for a local, he drove it here like this, got lucky.
    Lower timing cover was in 3 different pieces, the last guy only replaced the belt. Hydraulic tensioner was fully compressed.
    92 3000GT VR4
    Matt
  5. #6884
    Yikes!
  6. #6885
    I don't bite
    Southern IN
    Installed FIC2150's, new injector connectors, and tucked the injector wiring.
    So far I can't get them to idle as well as the PTE 1000s (which are for sale; set of 6). I'll keep working on it. Haven't tried playing with injector advance yet.
    Also installed HKS DLI and opened up the plug gap. That helped the idle some but still not great. Everything is working well in boost. Beat on it for awhile and tweaked the fueling to hit my targets. Raising timing next.
  7. #6886
    Nice garden hose fuel line. Is that -8 or -10?
  8. #6887
    I don't bite
    Southern IN
    -8 with wire cover over it so may look a little bigger than normal. Gotta feed the 14Beast!
  9. #6888
    Sep 2012
    Decatur, TN
    Hmm..PTE1000s you say?
    Trying to sell these 880s and hold out for something bigger. Worried that on E85 they'll be nearly tapped out and would require upgrading if I upsize from 14Bs down the road.
    That said, selling all these parts to get a Series 2 is priority. Once that's done I'll worry bout injector choice.
  10. #6889
    I don't bite
    Southern IN
    They were/are good injectors, but just not going to get it done for next year.
  11. #6890
    Twin Turbo verified
    Melbourne, Australia
    Spent 2 days cutting then polishing my car. The spoiler had faded out to white and the rear left qtr faded completely as well. This pic is 2 years old. It got twice as bad between now and then. Forgot to take recent ones.
    Went to this.
    Then this happened 500kms from my house
    which was caused by this...... After 50k kms the bolt holding the timing belt tensioner pulley came loose sending the pulley through the side of the timing cover and the lovely sound of valves hitting the pistons........
    Waiting install
    Build Thread
