Page 664 of 892 FirstFirst ... 164564614654662663664665666674714764 ... LastLast
Results 6,631 to 6,640 of 8916
  1. #6631
    Feb 2011
    Scottsbluff, NE
    Quote Originally Posted by slickwheel View Post
    Thanks for the stock PCV info (did notice the change from using one side vs two sides with a t on the passenger side, must of increased the flow even more). Wonder if I should throw one of these widgets inline to replace the stock PCV since it won't really work with the T on the valve covers and a barb fitting on the front...M/E Wagner Performance Products | High Performance Crankcase Ventilation Systems, I could tune idle and cruise PCV suck-age amounts for my specific motor/mods/engines age/adding a second large can/etc it would seem...
    That looks very interesting... I may end up looking into one myself if my KVs are still causing some of my smoking issues (along with 3SX return lines).
    Quote Originally Posted by deemo99 View Post
    I thought running the front KV only in place of the stock PCV was the best way to use KV? I have mine setup this way with the rear valve cover still connected to the bubble. Doesn't the KV do the same thing as the PCV but actually hold boost?
    Close, you want to run the front KV with the stock PCV on the same line so the PCV can regulate how much air is sucked through at idle, and the KV will hold more boost than the PCV.
    1995 Dodge Stealth R/T Turbo
  2. #6632
    drives with Drivers' gloves.
    Maryland
    Quote Originally Posted by DK77 View Post
    I went ahead and ordered the Dual PCV and Inline Adapter. Now I just need to order a vacuum gauge off amazon to set it up with...definitely going to post a review/create a thread once I get it installed.
    I wonder if it totally negates the need for the small krank vent under boost...I would think so since it positively seals...maybe the small vent could just add a bit of extra protection to the new PCVs internals when boost happens...
    Probably will have to repurpose those krank vents for cutch and brake booster valves or something now I guess, lol
  3. #6633
    Feb 2011
    Scottsbluff, NE
    I guess the question there is what boost those are rated for? I didn't really see anything on there about them being used in boosted applications. But you could probably combo one with a Krank vent and be just fine
  4. #6634
    Maryland
    What did you do today to your 3/S?
    Dual PCV widget, small Krank Vent, and twin air oil separators installed
    Got the vacuum gauge hooked up to it to set idle/cruise air suck-age then I'm out for a cruise. Hoping for some good results...
    Edit: inline dual PCV widget was definitely worth it. PCV suck-age is now fully controllable
    http://i45.photobucket.com/albums/f9...pshxxqlw4e.jpg
    http://i45.photobucket.com/albums/f9...psm8efyzsp.jpg
  5. #6635
    Sep 2012
    Decatur, TN
    Went to Harbor Freight, dropped $250 on myself.
    3 ton low profile jack on sale for $85. New creeper on sale for $20. 1/2" 700ft/lb impact on sale for 79.99.
    Happy early birthday to me
  6. #6636
    JNS Engineering verified
    San Jose, CA
    Had a rear steering power cylinder seal replaced for FREE
  7. #6637
    Sep 2012
    Decatur, TN
    My (semi) short term solution to trying to keep stealthy and hide the upgraded power. Long term will be a switch to SMIC and nice piping, but for now. Should do nicely.
  8. #6638
    Never finishes any verified
    Wake Forest, NC
    I got the engine all back together and the rebuilt ECU installed, cranked it up and... injectors are not pulsing...blah!!
    I need to dig into it more this weekend to see if I have spark and find out what is going on with the injectors now! if it's not one thing it's another with these damn cars...ugh!!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  9. #6639
    Sep 2012
    Decatur, TN
    First is my twin flywheel. very excited about that.
    Second is my new oil pan, which confused my girlfriend who was trying to figure out why I bought a used box of pampers.
  10. #6640
    San Jose, CA
    She will need those to keep the co-pilot seat clean when you get your machine running
