Page 663 of 892 FirstFirst ... 163563613653661662663664665673713763 ... LastLast
Results 6,621 to 6,630 of 8916
  1. #6621
    and a 95 too!
    April 2005
    Door Peninsula
    Washed her up! Not happy w alignment don't understand why they can't get it right only has camber and toe! Ran 12psi has been a long time, felt fast.
    1995 3000GT VR-4, 1 of 6 identical
    DR-16Ts, ARC2, 550s, supra pump, GReddy FMIC, Tomei BOV, RPS max full face, 3SX fuel rail loop, AEM wideband boost & oil pressure in stock location, Stillen DP, gutted rear pre-cat, Tanabe Touring Medallion catback, HHH datalogger, active aero sim w/3SX splitter, vac redux, Tein S KYB GR-2, Maximal control arms, 3SX poly bushings, ss brake lines, IPS rotors carbotech pads, ABS delete HKS EVC 6, HKS DLI, Maximal powder coat, 5hp chrome twin turbo plate, BSLCDBC
    1999 3000GT VR-4, 1 of 65 identical
    Jack-stand mod for now.
    it's probably fair to say that I've seen more cranks than a lot of other people on here.
  2. #6622
    Feb 2011
    Scottsbluff, NE
    Quote Originally Posted by slickwheel View Post
    Updated my drawing.
    Looks better. I forgot about the problem with just running one KV and no stock PCV though. The stock PCV also regulates the amount of air that is sucked into the manifold. With your set up the separator should keep you from sucking oil into the manifold like I did, but your idle may be a bit high, not sure if you could tune it out.
    1995 Dodge Stealth R/T Turbo
  3. #6623
    Never finishes any verified
    Wake Forest, NC
    Almost got everything on the engine back together after my thrust bearing issue. A couple more things to button up and add fluids and it should be ready for the road again.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  4. #6624
    drives with Drivers' gloves.
    Maryland
    What did you do today to your 3/S?
    Quote Originally Posted by DK77 View Post
    Thanks for the stock PCV info (did notice the change from using one side vs two sides with a t on the passenger side, must of increased the flow even more). Wonder if I should throw one of these widgets inline to replace the stock PCV since it won't really work with the T on the valve covers and a barb fitting on the front...http://mewagner.com, I could tune idle and cruise PCV suck-age amounts for my specific motor/mods/engines age/adding a second large can/etc it would seem...
  5. The Following User Says Thank You to slickwheel For This Useful Post:
  6. #6625
    and a 95 too!
    April 2005
    Door Peninsula
    I thought running the front KV only in place of the stock PCV was the best way to use KV? I have mine setup this way with the rear valve cover still connected to the bubble. Doesn't the KV do the same thing as the PCV but actually hold boost?
  7. #6626
    Quote Originally Posted by Unlogic View Post
    Replaced my AEM FPR with a Fuelab unit instead:
    I'm currently running an AEM FPR with no issues, but it has sub 7,000 miles on it.
    I'm wondering, why did you make the switch?
  8. #6627
    Essex, UK
    Started mine for the first time in 2+ years...
    That literally was the first fire after sitting since May 2012 ! Quite happy !
    Paul
  9. #6628
    Wonder if I should throw one of these widgets inline to replace the stock PCV since it won't really work with the T on the valve covers and a barb fitting on the front...M/E Wagner Performance Products | High Performance Crankcase Ventilation Systems, .
    That is an interesting widget.
    Oct 2011
    Sundsvall, Sweden
    Quote Originally Posted by J-Groove View Post
    The housing of my AEM FPR wasn't flat where it meets the banjo bolt so I a hard time getting it to seal properly.
  11. #6630
    Sep 2012
    Decatur, TN
    Well Supercar center got to Ninja today. Suh-weeeeeet
