Page 640 of 892 FirstFirst ... 140540590630638639640641642650690740 ... LastLast
Results 6,391 to 6,400 of 8916
  1. #6391
    TN
    So I bought one of 3sx "custom chrome billet oil caps", which I got for $4.95 since I had a $20 GC for ride of the month... needless to say I would have been pissed if I planned on using this "as-is" because it was gouged. But I had other plans for it. Let me tell you, I hate working with billet aluminum, it is a much denser material versus cast. Took me the better part of four hours of grinding/sanding to get to a "flat" surface. Anybody want to guess what's going on top ? I'll update once the other piece comes in. I still need to drill and tap a hole for a larger bolt than what came on it.
  2. #6392
    Dayum!
  3. #6393
    a tiny turbo? A spider? A diamond?
  4. #6394
    TN
    a tiny turbo?
    close, not a turbo... but something in a turbo I only polished the topside because I wanted to see what it looked like LOL. It will most likely be covered. Haven't received it, supposed to be here hopefully Saturday. I will need to clean and polish it of course.
  5. #6395
    Compressor wheel?
  6. #6396
    TN
    Compressor wheel?
    Yes... saw a couple of other 3/S with one and decided to make my own (since I couldn't buy theirs or con them into making me one)
  7. #6397
    Lol. I feel dumb. The picture just loaded this time around.
  8. #6398
    Jun 2011
    Sweden, Gothenburg
    Was exited to install my coilovers and then my usual luck struck with this pos car.. managed to snap a corroded m10 bolt
    What now? Drill and retap i guess... Off to rent some massive drill tomorrow morning. I bet that nut is tough...
  9. #6399
    Sep 2012
    Decatur, TN
    Ouch.. I've yet to try to tap the D's threads on mine..got damaged removing the OEM shock
  10. #6400
    May 2014
    TX
    I installed my rebuilt plenum, TB from April, injectors from Evotuner along with resistors and the phenolic spacers.
    Thank goodness I replaced the plenum, the old one had a bad VIC or something. When I removed the VIC motor to see about installing it on my new (to me) plenum the gear was stripped and black crap was all over the place. The shaft moved like crazy so I know the seals were bad. Hopefully it will run much better now. I'll need to pull the VIC motor off the new plenum and make sure it's not stripping too (I installed it per the instructions). I do not think the VIC was ever removed in the 16 years I've had the car so I'm not sure how long it's been bad or if it ever worked.
