Page 61 of 892 FirstFirst ... 1151596061626371111161561 ... LastLast
Results 601 to 610 of 8916
  1. #601
    Advanced Tech? verified
    I need to figure out what I'm using to fill the gap to the bumper cover, but it's about where it's gonna be...
    uhhh why is it hanging so low? are the subframe bolts all tight?
  2. #602
    Easton
    Dropped it off at gzp
  3. #603
    Man vs 3/S verified
    Kingston, WA
    He put a spacer on it for the angle he wanted.
  4. #604
    Not A DSM verified
    June 2006
    Utah
    Whats giving you trouble on the underhood bushings?
    If its removal of the old ones just jam a screw driver thru the center hole and kinda twist back, should pop right out.
    I was just being a bitch and trying to get it out without removing hardly anything. Once I removed the front inlet pipe I used the screwdriver technique and they came out nicely. I can't wait to give it a drive and see how it shifts.
  5. #605
    Banned J. Fast's Avatar
    Garage door weather stripping might fill that.
    Do you have any side pics full view? Is the splitter anchored to the bumper or is it pinned to the subframe?
    Your car looks like it has very nice paint BTW.
  6. #606
    Thanks J. Fast! The weather strip will work until I get the time to fab the aluminum filler.
    As R/T93 stated, I shimmed it down to have a 3/4 inch drop from rear to front. I will be putting turn buckles on when I find the right parts or find them online...
  7. #607
    No Show NG11 Not Verified
    Mesa, AZ
    Re-painted that last bit of trim.
    Went from..
    To..
    Its amazing how much of an improvement it was with 30 minutes of work.
    Your 1993 Mitsubishi 3000GT SL is one of 4310 that received VIN numbers. Based on the order of the serial numbers, your car was the 2685th out of the 4310 that were made that year.
  8. #608
    i'm guessing that since the tach uses PTU signal, it doesn't give an accurate reading when there's misfire.
  9. #609
    West MI
    ^ Yup. Im digging your wideband reading in voltage, is there a way to do that on any of them?
  10. #610
    Started stripping down the inside of the car. Really damn hot outside, 98 in the shade. Really on inside the garage.
