Page 609 of 892 FirstFirst ... 109509559599607608609610611619659709 ... LastLast
Results 6,081 to 6,090 of 8916
  1. #6081
    RTBOOST verified
    Florence, Wisconsin
    Quote Originally Posted by DK77 View Post
    ONLY if they are pretty & petite.
    Fixed...
  2. #6082
    Twin Turbo verified
    Melbourne, Australia
    he needs more stealth
    Only one stealth exists in Australia. If it came up for sale I'm sure John would be the first to buy it. The owner bought it new in the states and imported it when he came back home. Had it converted to RHD
    Anyway I got the coilovers today. As they have no markings on them or the ones on John's other car we had guessed they where apexi due to the similarities. However after some research I believe they are Blitz ZZ-R Coilovers.
    BLITZ POWER SITE : DAMPER ZZ-R
    For sale on ebay
    Blitz Damper ZZ R Mitsubishi GTO Z16A 6G72 Turbo 9 90 8 01 92784 | eBay
    Pics I took tonight. There are no brand markings on them at all. When comparing them to pics of Blitz ZZR's the lock nuts are slightly different and the lower one is black on mine but always red in the pics of the ZZR's.
    Waiting install
    Build Thread
  3. #6083
    St.Louis
    Messed with my shifter assembly today and was able to pull some slack out of the shifter. Oh, and I also worked on this:
  4. #6084
    JNS Engineering verified
    San Jose, CA
    Drove it to work so I can burn up some of this 91 pump and get ready to put some more 101 in
  5. #6085
  6. #6086
    Coldwater, MI
    Loaded the VR4 onto a trailer to get my tranny looked at. Pray for me 3/s friends.
  7. #6087
    Good luck, mine is sitting in pieces but will be together this weekend.
    MMM-Hmmm!
  9. #6089
    Twin Turbo verified
    Received my 3sx downpipe. Will hopefully fit it this weekend. Does everyone use gasket silicon on the joins? I would have thought that just a gasket was enough but this used one I received was covered in orange silicone.
    Also it has 2x o2 bungs on it. One at 90 deg the other at about 45 deg. Which one does everyone use? the stock one was at an angle but from memory the book says to mount it at 90 deg.
  10. #6090
    45 degrees is better for the sensor, condensation will drip off and not foul it. Using silicon on the gaskets is a sign of desperation... FWIW I had to use it on my IPS DP because the flanges warped and I couldn't get gaskets to seal all the way.
