I don't remember the size..only that its the larger of the 2 spacers that AutoZone sells...
Installed all new ECS struts and S-Tech lowering springs with 100% new OEM mounts/bushings/etc. Tomorrow morning it gets an alignment and then a nice bath.
Started porting/ polishing my TT heads again. Im about 8 hours in and half way done with one head. Mostly just smoothing out the runners more than porting much, but i have kife edged 2 of the 3 exhaust ports. These are going to flow real good when im done.
They look dirty...because they are lol. Photos dont do the ports justice though. I got rid of all of the ridges that are just inside of the valve ports.
And here's my engine currently...just begging to get finished.
I thought so to but the spring is sitting properly against the lower perch and the upper seat is lined up with the lower perch. Its also the same height on the other side.![]()
If you have 2 inch gaps then something is assembled wrong. The strut base and the top mount must be properly oriented. I have this setup and have less than two finger gap
