Too bad non of those mirrors where never amber light.
yeah, very easy to install just 5 wires (3 if you dont have a mirror with temp display). power, ground, 2 wires for the temp sensor, and then a reverse wire. the reverse undims the mirror when you put it in reverse. you can either tap into the reverse light wiring after the switch or just tap it into the ground wire (but then it doesnt undim in reverse). you can find access to the reverse wire in the passenger side kick panel and since I was running my wires down the passenger side a-pillar I went ahead and tapped into the reverse wire. works great.
Got a head unit installed. Installed subs. Fixed sagging driveshaft and re-calibrated my wideband sensor that I moved farther back in the exhaust so it doesn't overheat anymore.
1995 Dodge Stealth R/T Turbo
I do not have one, but the thought is to get one and install the sensor on it. And cut out some of my cat back, to install it.
You want the wideband in front of the cat, and 36" (of piping) from the rear turbo
No cats![]()
Didn't get to the dash yesterday, but I did take the wife to dinner in it. Crappy pic but oh well....
